Post Info TOPIC: Radio in a Coaster Ideas
We have an 85 Coaster and the radio is a digital one but crap, We bought a 2nd Coaster for the engine but the one in that is crap also. So what I am looking for is good radio reception, Mp3 playback and input jack. Where do people with Coasters install the speakers. Ours has 2 speakers (In roof lining) one about a metre back from the seats the 2nd one is 2 metres back further. I'm sure the speakers could do with an upgrade but where is the best place to mount them. The drivers door would be ok for right side but how difficult is it to remove passenger lining?
Merry Christmas to all
Cheers Allan
Toyota Coaster
Allan
Howdy Alan,
when I had a Coaster ( 77 mod ) I had two large speakers mounted high up in the over-head rear shelf, also another two on each side of the front passenger compartment above the doors, there was a new radio/C.D./ mp3 player fitted into the dash, in easy reach of the driver and passenger,
K.J.
From Coast to Coast, We'll see it all.......One Day
U.H.F  CH  18 /40  Say G'day.
You can get an App for your phone which allows you to connect to the almost any station in Aus and have it come through your radio. You will also need a connecting cable from your phone to the radio about $6.50 at Jaycar. As long as you have phone reception you have perfect radio.
Wassa
G'day Wassa
Sounds like the way to go, whats the name of the app.
Thanks
might be an issue as I'm pretty sure it is a streaming radio. which is DATA usage...
It's good if your not being charged for it...
juergen
J
Try alpine single din radio has bluetooth connectivity / ipod/cd player/usb input and headphone jack, try the new radio with the existing speakers and see what the sound is like, the blue tooth also has phone book search. The phone book search facility will depend on the type of phone you have.
Regards Jim
Its called Radio Australia. I use Aldi Mobile which uses Telstra G3 and is VERY cheap.
Wassa
I use internet radio all the time ( but that is easy as I have unlimited download )
http://www.sunshinefm.com.au/listen-live.html
http://www.smoothfm.com.au/station/smooth915
Here is a link to how much data you will use while listening to internet radio on a PHONE
http://answers.microsoft.com/en-us/winphone/forum/wp8-wpnetwork/how-much-data-does-internet-radio-uses/9a864217-53af-479f-8944-e8fcc2685a89
Cheers John
-- Edited by Cruising Cruze on Friday 26th of December 2014 10:51:04 AM
Here is a other good explanation
http://hypebot.com/hypebot/2013/08/how-much-of-your-broadband-allowance-does-internet-radio-consume.html
Patrolst I'll look into that Alpine unit as it has what I want/need Cheers Allan
-- Edited by Murraman on Sunday 28th of December 2014 08:15:06 PM
Toyota Coaster
Allan
Nice fitout, Looks neat. Speakers on ours will probably have to go in the drivers door, Passenger panel. Thanks for the photos. Cheers Allan
kiwijims wrote:
Howdy Alan,
K.J.
Toyota Coaster
Allan
If you are going for the conventional in-dash radio, and you intend to buy a quality unit (as you should), then make sure you have a quality antenna too. Some of the original equipment antennas are pretty ordinary. Both the radio and the antenna need to be good. Unfortunately that also means that you will probably have to pay more.
Good luck.
BJC
"A year from now you'll wish you had started today."
Morning Allan,
Have just been down the same path, over the past couple of years have gone from the Transit (Ford) radio, rubbish reception, tried two portables, some improvement, however lousy sound quality.
Just before Christmas I bit the bullet and had a Kenwood KDC X700BT http://www.ryda.com.au/Kenwood-KDC-X700BT-CD-USB-Player-with-Bluetooth-p/kdcx700bt.htm radio installed with an exterior antenna, a very good unit with excellent AM and FM reception, have been using it in the bush with good results.
Also a CD player, has a remote and a USB port so you can play music from a USB memory stick.
The only down side is like all modern radio's, it's not as simple to tune as the older dial type tuners, however a little time reading the manual takes care of that.
I'm sure there are others equally as good, however this does everything we need.smile
-- Edited by Santa on Tuesday 30th of December 2014 07:46:45 AM
Santa.
