Post Info TOPIC: Do Not Overtake Turning Vehicle Stickers
Is there a legal size for these stickers to back of Caravan and either side of van okay to be placed ??..
I think it is dependeant on the size of the Whole setup..
Normally the vehicles need to be over 4.5t and over a set length..
Check out the trucking forum's...
Juergen
Psst do a search on the forum's This topic has come up before..
j
J
Hopefully this will help Papou -
http://www.towingguide.com.au/content/rear_marking_plates.html
John I commend your patience and help to others.  Cheers Baz
Sort of still "on topic". I got some of the stickers in question plus a couple of others from FB but had Vantec applied to the new van before putting the stickers on, now they won't stick. So just keep that in mind if applying protective coatings etc. Polish might do the dame thing.
.. and you can also get adhesive stickers to the relevant standards that do stick well .. not sure if it would work for Dougwe .. yet untested there ..
look about .. and bear in mind that they do stick well .. no real good second chances .. hehe !
Jonathan     DMax & NewAge Van .. fulltime
KFT
Jonathan, can I ask where that photo was taken please.
looks like a lovely spot.
frank
apologies for being OT
Avagreatday.
Greens Lake .. Frank ..
Thank you all kindly for your replies:)..
 Not really if you know what you are doing.  I wrecked 2 stickers when I was fitting them to a truck, before I learned the trick. confuse
The trick is to apply - spray or splash soapy water to the area to be fitted.  Then, peel off the backing paper and put the sticker where you want it, slip & slide it until you are happy then....very thoroughly squeegee, wipe whatever way push all water out from under the sticker.  There should be NO bubbles remaining.
It is now in the right place and will never come off. smile
In regard to vantec, polish etc, a wipe with method on a rag should fix that.
Cheers Neil.
-- Edited by Delta18 on Tuesday 2nd of December 2014 03:11:09 PM
Neil & Lynne
Pinjarra
Western Australia
I did it a better way, as I bought a metal plate one and fitted that to the back of the trailer on both sides, as once I have the trailer hooked up to the bus it is just over 13 metres long.
Barry
 Just a hint I picked up from a sign writer years ago.
Wet the complete area plus a overhang, with dish washing soap and water (not too strong) and it gives you a good sliding base to adjust and position the larger sticker.
On a van with the corrugations in the metal skin, make sure you use a small wooden blade (ie a ruler) to push the sticker into the ridge.
Then leave it for 24 hours to dry.
Be good. I have photos on my facebook page.
Live long and Prosper
 Hmmmm why didn't I suggest that....about 5 hours ago? disbelief
Neil & Lynne
Pinjarra
Western Australia
Just thought I'd add this bit, sorry Papou,
Vantec are supplying a bottle of liquid they use so all should be good in the end. I might add also that I emailed Vantec and 1 hour later got a phone call from them that was friendly and helpful. If I wasn't quite so far away they would have come and sorted it for me.
Yep got the ones with alloy backing and used sikaflex to adhere it to back of Van left side.. Mind you they ar not that big in size and still thinking of getting the longer stripped ones with self adhesive backing??.
I think we are using the wrong stickers cry ... reckon this one is more appropriate
There are rules and regs for the do not overtake stickers and signs and their placement. This can be found on the NSW RTA site.
They must be reflective grade 2 RTA material.
M&D
Never stop learning.
Hi All,
At the last NSW State rally at Bathurst in March a representative from the RMS (Roads and Maritime Services to non-NSW people) addressed the audience. One topic he mentioned was putting 'Do Not Overtake Turning Vehicle' stickers on the back of caravans.
While stating that it was not compulsory for caravans to display the signs he pointed out that without a sign when making a left hand turn and swinging wide should a vehicle try to sneak through on the inside and your van hits them then IT IS YOUR FAULT!
With a sign is on the back if the same thing happens THEN IT IS THE OTHER DRIVERS FAULT! They have disobeyed/ignored a direction, being DO NOT OVERTAKE TURNING VEHICLE.
By the way, the signs are only to be used when the combined length of tug and van is over 7.5 metres. So it is a no-no to put them on the back of box trailers for example.
Murray
KFT
 thanks mate
I will get there one day soon I hope
Avagreatday.
Where can we get the stickers?
This might help -
http://www.ebay.com.au/sch/i.html?_from=R40&_trksid=p2050601.m570.l2632.R2.TR4.TRC2.A0.H0.Xdo+not+overtake+&_nkw=do+not+overtake+turning+vehicle&_sacat=50067
Thanks RL, any one know of motor registry, super cheap or similar?  Not a fan of Flee Bay.
Talk to Dougwe .. he bought some online ... good price .. and delivered to his nominated address
Most truck spare parts/accessory shops sell them.
Bill B
