Post Info TOPIC: Placement of power bits and pieces.
The batteries and and Morningstar Pro Star 15 Solar regulator are under the front mounted queen sized bed. To view the info I have to lift the end of the bed. How often do you monitor the regulator?
A cupboard has the led monitor for the two tanks and battery, also the TV antenna amplifier and a ciggy socket as well as the 240 stuff. I have an analogue voltmeter and ammeter. The voltmeter could mount up there to measure battery voltage. I also I would like to to easily  monitor battery charging amps of the solar and the Setec.
Any thoughts? I will have my auto elec coming in a couple of weeks so I need to have valuable jobs for him to do for me!!!biggrin
Aussie Paul. smile
Paul..
I think you can get a remote monitor for the "Morningstar Pro Star 15 Solar regulator"..
check out Ebay..
Juergen
J
Thanks Juergen, I found this BUT can't seem to find a remote to use with my Morningstar Pro Star 15 Solar regulator.
http://www.ebay.com.au/itm/25A-12V-24V-Solar-Regulator-with-REMOTE-MONITOR-MorningStar-SunSaver-DUO-SSD-25-/181470941771?pt=AU_Solar&hash=item2a4082d24b
Aussie Paul. smile
The Master
I have the Morningstar Pro Star 30. Thankfully mine is on the wall above the bed as I am paranoid and check it regularly throughout the day.
But I do have a problem with the waterpump switch being under the bed. First job for the auto electrician when I get home is to move it out where I can get to it easy.
Happy Wanderer
Don't worry, Be Happy!
 I might have to consider getting my cousin to shift it. I will tell him to bring a roll of 6B&S and 8B&S!!!!!!!!!!!!!! for all my jobs!!!!!!!!!biggrin
Aussie Paul. smile
Found this but not compatible with my Solastar 15...
http://www.morningstarcorp.com/products/remote-meter/
Maybe I could buy this  and sell my Solastar regulator.
Aussie Paul. smile
In a previous caravan the idiots placed the Morningstar Prostar 30 under the bed, stupid IMO, as you really need to keep an eye on it.
Being an ex sparky I rewired the thing to a cupboard using the appropriate heavy gauge cabling, simple job but fiddly getting the cables through so they didn't stick out like a sore thumb.
Make sure you also run a small fig 8 cable too, for the battery sense terminals as being more remote from the batteries it will give a true reading and perform as it should.
Dont think there is remote metering for the Prostar, there is for the Tristar 45 as I've got that now.
brian
