Post Info TOPIC: MATCH STICK MODELS.
MATCH STICK MODELS.
my van wrote:
Hi Mr D
I am still working on the confounded windmill
A lot of trial and many errors
The head and tail turns on a turntable , while the drive shaft is moving up and down  .
The drive shaft has a 25 mm action up and down .
There is still more work to do on it such as the stand platform etc,
Can I use a spray can to paint the mill ?..........it depends on how you do it.......
You can spray anything if you do it the way the paint was designed.
Are you to use spray cans...these are usually oil based paints and will need a primer and undercoat, and rub back between coats.
Water based paint doesn't need an under coat. you can put on 2 or 3 coats and only rub back after 2nd coat. and it is easier to rub back water based paint than oil.
but I prefer to use water based paint first 2 coats and get the finish l want, then it is easy to do small fiddley little things with oil paint if l want to.
 Some people say yes some say no
Match stick models are a bit different to ordinary  pine wood.....don't know why you think this. wood is wood and they are stuck together with wood glue, no different to building a house.
Spraying the model with spray paint seams to be an easier option if it will be ok
I can not add a water pump because the shaft action ic too fast  for the pump  valves to handle ,......try changing the angle the wind hits the blades  so that whey don't run as fast. just like the real thing. a full size wind mill has the means to do this.
Well what do you think?
Cheers from Paul
Ps.  the coloured  sections of the crank cover  are paddle pop sticks ( I wont use them again )
 Paul, it takes me up to 12 months to finish a model, so don't rush it. Hope this helps a bit.
-- Edited by Dunmowin on Tuesday 26th of May 2015 08:19:29 PM
«First  <  1 2 3 | Page of 3  sorted by
