Post Info TOPIC: LPG cylinder compartment air ventilation
NOT ONE caravan or Motorhome manufacturer installs a small airvent(size based on volume of compartment)in the top of the compartment door as required by the LPG Standard. There is also supposed to be a single 25mm diameter pipe drain in the base of the compartment.The bottom of that pipe or tube is to be cut on an angle giving a champfered end which must face away from the forward direction of travel. Goes to show how stringent inspections are by the Authorities. Where are the $fines and prosecutions for non-compliance?
Good point Sheeds
In the majority of cases the cylinders on a C/V are in the open on the drawbar..
In the case of where the cylinders are in a sealed compartment
 The vent can be of any shape so long as the area is no less that the area of a 25mm (1") hole.
Some compartments have a vent in the door or have a gap at the bottom of the door..
I can assure you that any gas fitter singing off on an installation would check to see that the compartment is vented correctly..
oldbobsbus@gmail.com
The gas cylinder compartment of our Kea Endeavour is certainly vented.
Santa.
Our Starcraft has an open bottom and a cowl over the top. I agree with Bob, no gasfitter worth his salt would dare sign of a dodgy job.
Hey Bob, hope you are well mate.
Live long and Prosper
Are those doors on those supposedly sealed gas compartments actually sealed doors? Maybe they a have sufficient gap around the edges.
 The gas compartment only has to be sealed to the interior of the vehicle and as such if the door is on the outside of the vehicle it doesn't have to seal.
Having said that I always seal the top and sides of the door to keep water out and leave the bottom unsealed ..
Coromal van I have complies
