Post Info TOPIC: home internet speeds adsl
hi guys  , for those that are on adsl or adsl2+, what is your speeds?
I' just changed from bigpond to tpg, hoping it might improve , but no good
who are you with and what are you getting, speed wise??
I would give anything for cable internet..
-- Edited by milo on Friday 17th of October 2014 12:06:37 AM
The Drewsterz my band site
Milo Online  my personal site
Wow Milo, that download speed is abysmal ... slower than your upload speed. Suggest you keep checking and also try the test using different servers. If there's no improvement start complaining to TPG. Was Bigpond this slow? As a reference, my result to the same (I assume) Optus server in Sydney is 13.03Mbps download, 5.94Mbps upload, and 50ms ping. I'm near Yeppoon in central Qld on Bigpond with a 4G wireless modem operating on 4G with only one bar of signal strength. I assume you're still on the NSW south coast?
Joe
(1)Changing ISPs won't necessarily increase your speeds, a major contributor for ADSL2+ is the condition of the telephone wiring in your residence. (2) Another possibility is there is so parameter in your modem router that is not right. (3) Finally TPG has on its homepage a Google maps site that your can put your address into and see what sort of speeds other TPG customers near you are getting and your theoretical maximum speeds from the exchange closest to you. I've been a TPG customer for years they are OK. I would investigate 3 first then 2 (TPG also has their modem parameters on their site) and as a final resort (1).
If we are going to be altruistic I want to get something out of it
Here's mine Milo
I would treat the speed test site simply as a guide. I tried this 3 times each with wildly different results from below 6Mbps to above 10Mbps. The whole point of these sites is to get people to buy their "solutions" for slow speeds, so take them with a grain of salt.
 Yep, would have to agree with you there Muskat.
Hi Milo
Ping 59 ms
Download 7mb
upload .35 mb
yeah it was the same when I was with bigpond..
This is my Speedtest.  Work is almost finished in our area on NBN, we should be connecting fairly soon I hope.
Neil & Lynne
Pinjarra
Western Australia
MY23.5 Ford Wildtrak V6 Dual Cab / 12/2025 Silverline 22.68.5
Hi Guys whilst this is not about ADSL, currently we are connected to NBN fibre service via iinet, we purchased the modem router from them when we signed up, it was almost a year when I thought this is not much faster than ADSL. Ran heaps of test using those speed test sites and everyone gave a different report.
To their credit iinet sent me a new modem/router the results were the same, they then supplied a different modem/router no luck again, during this period I was given a web address that was more accurate with it speed test.
If you have a fibre NBN service you don't actually need a Modem/Router, you can plug the computer directly into the NBN box via a network cable, when we ran the test the speed delivered was near on perfect, from that I decided that all I needed was a good high speed wireless router with a WAN gigabit port and 2.4/5 ghz wireless, after setting up with the new router no issues with speed.
iinet provided a full refund on the hardware I had purchased from them and a discount on services charges for the next 6 months.
I suspect unless you buy a high end Modem/Router you may encounter speed issues, I recall when I was with TPG I always had good speed perhaps it was because I ran a separate modem and router.
I will search for the web address for the speed test, if I find it will post it for you
PJK
Living in Bellerive, Tasmania, we are on the NBN.
At the changeover, our service provider offered 3 different speed settings, at 3 different costs.
Being of Scottish extraction, we opted for the slowest and cheapest.
I have occasionally tested our speeds and can say with confidence that we have all the above beat by about double.
Ping - 22 ms.
Download - 19.35 Mbs
Upload - 1.96 Mbs.
PJK
Now that food has replaced sex in my life - I can't even get into my own pants!!!!!!
Ping - 22 ms.
Upload - 1.96 Mbs.
PJK
 Which is about 20% of the capablilty.
PJK
Ping - 22 ms.
Upload - 1.96 Mbs.
PJK
 Correct Troopy, but sufficient for our needs, and cheaper (but much faster) than our old connection.
We actually save about $40 per month with the NBN / home phone bundle.
More for less is always a good deal.
But not all was good during the changeover - they neglected to tell us that our monitored alarm system would need a $600 upgrade, and that the phone had to be plugged into the NBN box where it terminates at the house connection. Either that, of you have to have the house rewired for the alarm and phone lines.
PJK
True...
my modem is a Netgear N600 modem/ router.. .wasn't exactly cheep earlier this year
when I bought it...
should I try another mode?
No Milo
It is just that you to far away from your Telecom exchange Box that you don't get the speed you want
Cheers John
Ps maybe you get more luck when they put the new NBN network in
thats what they keep saying.. but who here lives next door to their exchange??
Download 32.65
Up  .......... 1.19
Latency (Ping) 29ms
Jitter 4ms
That's on Telstra (HFC) cable at 10.30pm ... much slower (around 15 down) at peak times .. Lots of students in my area.
Won't get any better with the mongrelised LNP FTTN NBN.
