Post Info TOPIC: connecting wires ???
It seems that this strip light has 3 parts in there LED
Can I make from B R & G  one connection ???
Cheers John
I have a similar LED strip and I have joined the three together.Each of of the solder tabs provide different level of brightness.The three joined together gives the brightest light.Positive lead to the + tag and -ve lead to the other tags as required....cheers Peter.
SOME  POLITICIANS  AND  BABIES  NAPPIES  SHOULD  BE  CHANGED  OFTEN FOR  THE SAME  REASON.
Thanks Peter
I will solder them together
Photo193.jpgPhoto194.jpgYou can buy little push on clips that fit the ends.Its a bit of a scam that they don,t come with the light strip. Will try to post photo. Bill
-- Edited by bill12 on Thursday 2nd of October 2014 05:58:43 AM
Press the camera shutter button half way and allow time for the camera focus on the subject before pressing the shutter all the way, Bill. If the camera has a problem focusing because the subject is too close, select macro (the flower icon). When ever you take any photo with a digital camera, always press the shutter in two stages with a pause between.
Gary
Too early in the morning for pics. I have to go FISHING!. Will try next time. Bill
