Has anyone in encountered adding a generator driver by adding another pulley or a larger fan belt.
I have a 1.5kva generator that the motor decided to **** it self the cost to replace the motor is uneconomical, so the little mouse turning the wheel thought is it feasible to mount the generator under the bonnet and drive it off the ute's motor.
I assume that either I could have a pulley added to the motor or after mounting use a longer fanbelt (yep I understand whatever works the biggest drama is working out the correct size pulley for the generator)
The next question is where do I mount the electrics, suitable size cable from the generator to the relocated electrics, from there to an Anderson plug at the back of the ute and then Anderson plug wired into the caravan switchboard.
Why you ask I would like to run a standard fridge in the van, and when on the move there is 240v power available along with the portable generator for when we stop where the is no power.
I have heard of this being done, is it worth it or am I whistling dixie
The problem being that the generator needs to run at a fixed speed to give 50HZ. If its a 2 pole genny its 3000RPM or 4 pole is 1500RPM. Not realy practical if driving as RPM is going to vary. Probably ok if you are parked & fix the revs!!
It is not uncommon to add a second alternator to the motor to provide power to the 'house'.
This can then be 'tuned' to provide optimum voltage without the 'smarts' of modern alternator electronics.
It is much more efficient fuel wise to do this than run a conventional generator which are notoriously inefficient and polluting.
I was looking at fitting a commercial generator to a PTO on the light truck but after the costs got way out of control I've now decided to fit additional sola panels, batteries and controllers
duplicating what the van will have. I like the LION battery over Lead acid too. Definitely a 200 amp alternator will be needed.
I am no electrician but I can see that if you try to run 240v to your van, regardless how it is generated, via an Andersen Plug you are inviting more trouble than I weigh! You won't live long enough to read all the posts telling you it can't / shouldn't be done.
Cheers Neil
Neil & Lynne
Pinjarra
Western Australia
MY23.5 Ford Wildtrak V6 Dual Cab / 12/2025 Silverline 22.68.5
One simple quick answer
YOU DO NOT !!
A highly experienced electrician ,who is aware of ALL the risks & regulations could make a" reasonably safe "system
A DIYer to attempting such, could end up ELECTROCUTING himself or some one else.
ALL 240V ,no matter how it is generated /obtained can KILL, unless everything is done correctly .
ALL States of Aus have severe restrictions on who can do any 240V work
For Mr average about the limit that he can do is make plug connections
It would be a professional completed project, way out of my skill set
Hi Gundog,
Others have said most of the answers but here is my summary.
It is not feasable to drive an alternating current, AC 240 V, generator from a vehicle engine which is not at a set governed speed. The cycles would be constantly varying as the engine speed goes up and down. That would not be suitable to drive an ordinary fridge or any other AC motor. If you rev the engine the generator may be damaged by the high revs and the voltage may rise above safe limits.
The 240 Volt wiring is potentially dangerous as has been said and would cost more than its worth to have done properly and safetly. An anderson plug does not have a place here either.
There are other ways to achieve what you want but this is not worth spending any money on, and it may kill someone as well.
Hi Gundog,
Unless it's an inverter generator. However, I agree with the rest of your post re-dangers.
-- Edited by 03_troopy on Wednesday 24th of September 2014 10:21:55 AM
oldtrack123 wrote:Yes. an inverter generator does have a speed tolerance
But to what extent?
The actual generator in an inverter generator is a DC machine, therefore engine speed has no influence on the OP frequency. What does matter is that the generator speed is sufficient to produce sufficient DC power to drive the inverter section.
The second thing to worry about is over speed. It's easy enough to work out the gearing for generator speed at the tug motors cruising speed. However when you have that correct, Will the generator self destruct at hill climbing or heavy acceleration revs? Remember those generators are designed to work at a narrower range of speeds than the alternators in auto mobiles.
PeterD Nissan Navara D23 diesel auto, Spaceland pop-top Retired radio and electronics technician. NSW Central Coast.
It is not uncommon to add a second alternator to the motor to provide power to the 'house'. This can then be 'tuned' to provide optimum voltage without the 'smarts' of modern alternator electronics.
Ahh, I think we are looking back to the days when it was possible le to swing a hammer in a motor bay to repair a Holden or Falcon motor. Your Ocka may have this but what of the modern vehicles? We used to install 2 kW generators in police and fire vehicles to power Stem Lights (flood lights that rose up on an ingenious stem that came out of a can on the top of the vehicle.) I have not seen a modern vehicle that would accommodate that generator.
Most small generators do not have a complete self contained generator unit. It generally has only a rear bearing and relies on the engine shaft to support the front end of the rotor. Or the generator rotor is fully mounted on the engine shaft with no seperate bearings.
So to seperate the engine and expect to get the generator to be driven in some manner by a pulley somehow from a belt is actually an engineering exercise that would not be easy to do. Don't bother starting unless you want the work.
