Post Info TOPIC: Blocked toilet
Blocked toilet
Hi all
not a nice subject but what chemical can I buy (at BCF) that will break down solid waste.  We have a blocked toilet and before anyone asks, its not a cassette or ordinary run of the mill loo, this is a rolling stone special like the rest of the bus.
I need to get something to pour down the loo as we are going to be away from the bus for a couple of months.
thanks in advance
d and g
KFT
Bunnings
look for "drain opener" and follow the instructions and safety warnings to the letter.
frank
Avagreatday.
will have a look at that.  thanks
d
What type ? If it's like house ? The good old fashioned mop plunged into bowl works well..
disbeliefdisbeliefno not like a house - as I said its a rolling stone special.   there is a toilet  you pump flush and that goes into the holding tank which is what has clogged up
could not get drain opener from bunnings - have got drain clean - will try that
also have chucked 2 lites of white vinegar down it - maybe should try 2 liters coca cola - they say it rots nails!!!!
-- Edited by rollingstone on Tuesday 9th of September 2014 07:28:31 PM
TAJ
maybe try white vinegar and bi/carb sodawink
The Happy Helper
Maybe half a container of minimum 34% sodium percarbonate Woolies brand clothes and nappy soaker - it breaks down "solid" product - so well that it is used to "start off" septic tanks!  Cheap as well!!!!
jules
(Ben, aged 10)
Boiling water on top of bicarb soda. Breaks down all manners of fats.
Larry
Whatever you do don't use a common fertiliser .. It will clear it ... All over the block !!
 that would be interesting - not haha
Dont know if you have access to a pressure washer, those Karcher type things, my mate had a similar problem with his holding tank on his usa made unit.
You can get a drain cleaning hose attachment that fits on the Karcher wand and can be fed down the toilet or up the holding tank drain outlet, while jet cleaning it as it goes.
Wear overalls and have a large container under the outlet to catch the muck as it comes out (and maybe a nose clip) I was shocked what came out of his blockage but now all good.
The cleaning hose and jet head are very flexible and will go up or down from either end, just make sure it is well in the pipe before pulling the trigger !
After using his I went out and bought one and regularly blast out my grey water holding tank now.
-- Edited by banjo on Friday 12th of September 2014 10:30:20 AM
brian
