Post Info TOPIC: "LOOK-OUT W.A. HERE IT COMES AGAIN !!!
Get ready now for dangerous weather from Kalbarri to Eucla
Sunday 7 September 2014 - 6:10 PM
If you live south west of a line from Kalbarri to Mount Magnet to Kalgoorlie to Forrest you need to get ready now for dangerous weather coming tonight and into tomorrow morning.
This includes people in Kalbarri, Northampton, Geraldton, Jurien Bay, Dalwallinu, Southern Cross, Kalgoorlie, the Perth Metropolitan area, Mandurah, York, Narrogin, Katanning, Bunbury, Busselton, Margaret River, Bridgetown, Albany, Esperance, Eucla and surrounding areas.
This type of weather only occurs once or twice a year and is likely to cause major damage to homes and make travel dangerous.
WEATHER DETAILS:
As at 5.13 pm on Sunday 7 September 2014 the Bureau of Meteorology advises the passage of a strong cold front from Sunday evening is expected to cause widespread damaging winds to 100 kilometres per hour that could result in damage to homes and property. Damaging winds are likely to develop over the Southwest Capes from about 8pm Sunday night and extend to the Perth Metropolitan area around 10pm. The risk will then extend eastwards to reach Kalgoorlie and Esperance by about 5am Monday morning and Forrest and Eucla after 8am Monday morning.
In isolated areas southwest of a line from Jurien Bay to Merredin to Bremer Bay, dangerous gusts in excess of 125 kilometres per hour could cause significant localised damage or destruction to homes and property with the passage of the front.
Thunderstorms and small hail are also forecast along the southern coastline and extending north to Perth.
Tides will be higher than normal in coastal parts from Kalbarri to Eucla and may result in flooding of low-lying coastal areas. Dangerous surf conditions are likely which could cause beach erosion.
The passage of this cold front will be followed by another strong cold front on Monday afternoon. This is also likely to produce severe weather over southwest parts of the state and a separate Severe Weather Warning will be issued for this event on Monday morning.
These two strong cold fronts are expected to be windier than typical fronts and are likely to produce the kind of weather that is only seen once or twice a year over southern WA.
: K.J.    u95.gif
From Coast to Coast, We'll see it all.......One Day
U.H.F  CH  18 /40  Say G'day.
I hope it holds off till we drop some of our campers at the airport tonight for a midnight flight and get home again.
Sue and Phil
Going by the forecasts, you have until 10.00pm tonight before the Storm will strike,
best of luck there Sue,
take your wellies with you ,hmmhmmhmm
K.J.
RE:
Take care all and hold on tight. I hope you are all safe.
RE: "LOOK-OUT W.A. HERE IT COMES AGAIN !!!
We are about to head off now, will probably have a coffee at the airport with them (and make sure their flight hasn't been cancelled) then head home hopefully before it gets too bad.
Sue and Phil
RE:
Take it easy Sulfil and keep safe.
The Happy Helper
We have battened down the hatches! Hopefully we might miss it.
jules
(Ben, aged 10)
Well we are home safe and sound, just did a drop and run. Bit wet between Wanneroo and the airport but no rain all the way home. The wind is picking up a bit now.
Sue and Phil
Hope all over in the wild west are safe and sound and got through the night OK?
i presume you sandgropers will send it over to croweater land in next day or so.biggrinbiggrin  keep safe over there.
Dave S
iv'e lost my glass.
Master (of Mischief)
thnaks K.J. our suburb is not on your list so we should be ok biggrin
We had some heavy rain and quite a bit of wind over night but no damage that I can see as yet.Will wander around and see how the campers faired once I have had some coffee.
Sue and Phil
 same down our way sufil, I have not heard any news this morning, may turn tv on later.
Same in Mindarie. There were a few branches lying on the road on the way to work this morning.
Kathy tells me Ocean Reef was hit badly and some houses suffered damage and the wind was strong enough to shift some containers at Fremantle. I'm glad I'm not at sea.
Bryan
"TOTAL DISASTER"  here on South Side this morning,
I've just been around the property, couldn't see much damage at first, until I looked up.
"Not happy Jan"  that Dockers flag cost a small fortune,
thanks to the wind last night, it now is rather shot to bits, sure hope it doesn't signify their A.F.L. future results.
K.J.   crycrycry
Looks like that's been docked for sure KJ.
The Happy Helper
Wow! What a night - took note of Kiwjim's advice, and put the awning up, things away, and generally closed up for the onslaught - and it came - rocking and rolling, Oldboar who is just behind us was up dropping awning ropes and putting awning up in the early hours, but all is ok I think - msg, next door hasn't surfaced yet, so apart from some wind rocking her van around, she is most likely ok. DougF, down the yard a bit obviously did a rush out and got his awning up, but his satellite dish took a nose dive into the ground.
Apart from that, we are all ok, can't see any trees or branches down from here - so all good. Pity some of the people who live in houses I have just seen on the news - roofs off, trees down and no power! And maybe more to come today - a good day for inside I think.
jules
(Ben, aged 10)
Keep holding on tight Jules. I spose someone else is still horizontal and not yet excited smile
The Happy Helper
How did you guess, Doug??????
jules
(Ben, aged 10)
 would that be Billeeeeeeeee ?
Then you just send it on over east Dave wink smile
Inner north suburb of Perth was ok, noisy and high winds but where we were can't see any damage, our local park usually loose a few branches but haven't seen it yet.   Other suburbs did not fare as well. hmm
Edit:  Just had a look across the road, there is a large gum tree there at least 60ft high right next to some units, I saw a "little branch" hanging down towards the ground before I noticed the rest of it snagged inside the main tree and resting on the branches there, at least about 15 foot more. Luckily the branch had fallen away from the units (double story) and not onto the roof it overhangs....hmm
-- Edited by Vic41 on Monday 8th of September 2014 11:27:20 AM
Bit breezy here at present but the sun is out .
Sue and Phil
The Happy Helper
jules
(Ben, aged 10)
Oh Heck = maybe I should have gone to the CP in Eucla. Have come 25km further west to a camp. Was hoping the wind would die down so I could carry on this afternoon. Am tucked in some scrub~``` Will let you know if I survive!
Came screaming in at Kalbarri around 1-00am, slide out and awning already put away earlier thank goodness ! lots a rain but otherwise unscathed, apart from a lot of rocking and rolling.
Pleasant sunny patches this morning but the ocean is still very angry looking !
brian
You headed over to WA again Spida?  Where too this time? confuse
Stay safe and don't park under any trees if possible. smile
Back to Yanchep to house-sit for November then...... back to MacKay by late June next yearsmile
Sounds good Spida.....not far from Sufil's place either...smile
You might bump into some of the "Greens" mob heading roughly in your direction in WA smile
-- Edited by Vic41 on Monday 8th of September 2014 01:20:24 PM
Hey, if you gunna send it East please wait until I have flown over to Adelaide and back tomorrow. I'm not good in a plane at the best of times let alone if it's a rock'n and a roll'n. Not too keen on them hitting too many pot holes either.
Will submit your order to Odin Doug, but he's like Wombat, you can't trust him...  wink biggrin
