Post Info TOPIC: portable /fridge/frezzer
Help needed , What is correct temp.to set for freezing in 35lit.as doesn't seem to be freezing ,going away tomorrow. thanks
N.r. fredericks
Why dont you just set it to the coldest and work from there..smile
oldbobsbus@gmail.com
KFT
Hi Noelene, most freezers store at a temp of -18 deg C
If your stuff is already frozen when you place it in thefreezer you can keep it frozen at -10 deg C
hope that helps
frank
-- Edited by KFT on Friday 5th of September 2014 05:48:01 PM
Avagreatday.
thanks all seem I didn't have it set cold enough
N.r. fredericks
They can take quite some time to pull the temperature down - if you fill the freezer with food at room temperature and set the temp at -20 it can take 48 hours to go that low.
How colder the better
commercial freezers run way below minus 20 C
Cheers John
