Post Info TOPIC: 20 Practical Uses For Coke...
1. Removes grease stains from clothing and fabric
2. Removes rust; methods include using fabric dipped in Coke, a sponge or even aluminum foil. Also loosens rusty bolts
3. Removes blood stains from clothing and fabric.
4. Cleans oil stains from a garage floor; let the stain soak, hose off.
5. Kills slugs and snails; the acids kills them.
6. Cleans burnt pans; let the pan soak in the Coke, then rinse.
7. Descales a kettle (same method as with burnt pans)
8. Cleans car battery terminals by pouring a small amount of Coke over each one.
9. Cleans your engine; Coke distributors have been using this technique for decades.
10. Makes pennies shine; soaking old pennies in Coke will remove the tarnish.
11. Cleans tile grout; pour onto kitchen floor, leave for a few minutes, wipe up.
12. Dissolves a tooth; Use a sealed containertakes a while but it does work.
13. Removes gum from hair; dip into a small bowl of Coke, leave a few minutes. Gum will wipe off.
14. Removes stains from vitreous china.
15. Got a dirty pool? Adding two 2-liter bottles of Coke clears up rust.
16. You can remove (or fade) dye from hair by pouring diet Coke over it.
17. Remove marker stains from carpet. Applying Coke, scrubbing and then clean with soapy water will remove marker stains.
18. Cleans a toilet; pour around bowl, leave for a while, flush clean.
19. Coke and aluminum foil will bring Chrome to a high shine.
20. Strips paint off metal furniture. Soak a towel in Coke and lay it on the paint surface.
Now can you imagine what is does to your stomach lining? Who needs the household and cleaning section at the hardware store when we have Coke.
Acknowledgement to;
Read more: http://dailyhealthpost.com/20-practical-uses-for-coca-cola-proof-that-it-does-not-belong-in-the-human-body/#ixzz3BrLb7F6g
Follow us: @dailyhealthpost on Twitter | dailyhealthpost on Facebook
That stuff is lethal, my brother in law was addicted and the Doctor warned him to stop drinking it.  He felt much better, and lost weight.
Any way the wind blows
Spiritualists and tarot card reader
Vinegar does exactly the same and it doesn't contain sugar.
You can also drink it I believe... Not that I would.. eeeek.
Acknowledgement to;
omg. gotta me some coke. got some housecleaning to do.
I knew someone who was a plant operator Lesley, used to drink it by the bucket load when he was working, stuffed his kidneys up and he ended up on dialysis.   Not sure if he is till alive.
en.wikipedia.org/wiki/MythBusters_(2003_season)#101_Uses_For_Cola
If you trust the MythBusters methodology, some of the claimed uses for Coca Cola were confirmed while others were debunked.
I haven't touched the stuff in a long time, but a friend who is a migraine sufferer "needs" a litre per day to stave off his attacks. He claims it's the caffeine that gives him the "protection". In fact my brother was trying to cut down on his coffee intake but found himself unconsciously substituting Coke.
Crikey a litre a day.. let's see that's about 30 teaspoons of sugar....
Now there's a liver problem.
I gave up Coke about 30 years ago I was drinking 2-3 ltrs every day, glade I stopped.
I would be dead now I recon if I kept going. Tryed Pepsi Max but give that away as well. now I drink my wild Turkey just with Ice.biggrinbiggrinbiggrin
The Hats
Ron
It is better to beg forgiveness than to ask permission. :D
In Memoryof my Dad
Bacardi & coke myself, have to change to Bacardi & Lemonade . i think my RED might have a little bit of sugar in it, bugger.
Dave S
iv'e lost my glass.
Sounds like it could be a good drop for wombat biggrin
I can say that now cos he is in lock down  without his poota smile
It's a pity vinegar is not as palatable (as a drink) because it's actually very good for you.
Gary
I wrecon coke is great I think it is that good it would mend a broken leg, been drinking it for years,mind you I have never had a broken leg,
bit parshal to a dash of vinegar as well a pretty big dash.
Lance C
-- Edited by Olley46 on Monday 1st of September 2014 01:40:34 PM
-- Edited by Olley46 on Monday 1st of September 2014 01:43:30 PM
At school we had a teacher who frequently smelled of Metho...
Bogga Barns was his name. He showed us the tic tac toe scars on his back the Japs carved in him when he stayed at hotel Changi.
Bit off subject I know but I'm old ok...
We had a fire instructor at Rookies in Edinburgh back in 72 that would disappear every so often from class and come back smelling a bit flammable too Cloak..
Coke's not bad for making cheap bourbon drinkable either.. ;)
But does it go with Bourbon ?disbelief
Dick.
