Post Info TOPIC: Help with portable solar panel.
Me again. biggrin Needing more help. I bought this a couple of months ago,
http://www.ebay.com.au/itm/161340795730?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
I have read that having the regulator that far away from battery is not the best. Can I remove the supplied regulator and feed into the 15 amp regulator that the rooftop solar panel feeds into?
Aussie Paul. smile
HI Paul
That will depend on the panel sizes  you have on the roof.smile
If They exceed 120W the answer is NO
PeterQ
oldtrack123 wrote:
HI Paul
PeterQ
 The roof panel is 120 w Peter.
Aussie Paul. smile
aussie_paul wrote:
oldtrack123 wrote:
HI Paul
PeterQ
Aussie Paul. smile
 HI Paul
Iin that case, yes.
Remove or bypass the reg on the portable panel & feed into the VAN rgulator[ in parallel with the existing panel]
PeterQ
