Post Info TOPIC: Stoves and BBQs
Stoves and BBQs
If your running your webber on a baynot on the van do you still need the regulator on the webber hose?
same question goes for a protable gas stove
allan
Mitsubushi Triton Diesel Twin Cab
Concept Ascot ll  20.6ft
Check to see if you have a regulator between your gas bottles and the gas line. We have, and run the weber without its regulator hose.
no i have a ziggy bbq with a bayonet fitting installed to van and it uses the same regulator fitted to the van,
the portable gas stove may be different pressures so you would need to check that out ,
as i understand it the hose that fitted to my ziggy has a large hole but on some bbqs the hose has a very small hole which is a higher pressure so would need its own regulator,
take your time and hurry up
The regulator should be on the main gas bottles, no need for another. Just check to make sure.
Safe travels
Live long and Prosper
Most portable gas stoves run on high pressure gas they will not run with a regulator in the line, if it is a high pressure gas stove it needs to be connected directly to the gas bottle.
David
Ignore the last one, Allany. Another case of people not reading the post correctly. Webers, Ziggies & virtually all gas barbecues are low pressure requiring a regulator in the line. If your unit presently connects to the bottle via a regulator, provided your rig has a regulator between the gas bottle & bayonet fitting, you'll not need a second.
Darrell & Sandra
Love the bush & our native environment. Conservationist, not a bloody Greenie.
allan
i agree with oldbar. you have a regulator on your gas bottles thats OK.  CAN'T ANSWER YOUR SECOND QUESTION . i have a mains BBQ at home still have to have a regulator on it.
Dave S
iv'e lost my glass.
TAJ
never used a regulator on any lpg bottles only operating valve on
top of bottle  open  close
TAJ
just went back into TECHS CORNER  a very interesting BLOG entered by Rheo47
on the 21/7/14  go through all pages and it shows bayonet being inserted into
bottle no regulator      takes time to read all but worth it
                suenray
All propane and LP gas applications require the use of a regulator
TAJ are you saying you don't have a regulator on your gas bottles, what is a valve the same thing.
A pressure regulator is a valve that automatically cuts off the flow of a liquid at a certain pressure . they are used to allow high pressure fluids to be reduced to safe usable pressures
Dave S
iv'e lost my glass.
TAJ
ELGAS   QUOTE
                      a gas line pigtail OR  regulator  screws into the large female  threaded opening
                      on side of the valve   UNQUOTE   so the valve & regulator are a different connection
                                    suenray
TAJ
GLENELG     i was not switched on properly  please accept my apology
                   i am wrong there is a regulator further down the line
     TAJ
           if you don't use one you are very lucky to be alive,  edit we must have posted at the same time . yhats OK
-- Edited by Glenelg on Saturday 9th of August 2014 08:58:34 AM
Dave S
iv'e lost my glass.
David
           edit (This is the post above that is not good. )     our 4.5 & 9 gas bottles on or in the proper  place MH or caravan should have a regulator on it at all time.  it is under pressure.
            you cannot be to careless with gas  or you may not be on this planet for long.
-- Edited by Glenelg on Saturday 9th of August 2014 09:18:23 AM
Dave S
iv'e lost my glass.
I stand by what I said in my post most portable gas stoves are designed to run on high pressure gas they are not designed to run on low pressure, go and have a look at some portable gas stoves in your camping shop, they are meant to be connected directly to lpg gas bottles, in most cases these are small gas bottles, but they can be run on larger bottles.
David
Suffering hell, guess we'll be seeing the obituary of Roving dutchie sometime in the future. Butane stoves (Coleman, Campmaster, etc) run on their own specific cylinder types. To attempt to run them on Propane (LPG) without a regulator is a shortcut to a box. By the way, LPG stands for low pressure gas.
Darrell & Sandra.
PJK
Damn, and I always thought LPG stood for Liquid Petroleum Gas.
You learn something every day. Or do you????
PJK
Now that food has replaced sex in my life - I can't even get into my own pants!!!!!!
oldboar wrote:
....................................................... By the way, LPG stands for low pressure gas.
Low pressure gas, my foot !!!
I'll go with Liquified Petroleum Gas ...................
http://www.originenergy.com.au/2363/What-is-LPG
Dave S
iv'e lost my glass.
PJK
 No Peter, think there may have been an ale or two too many catching up.  I stand by the rest but that bit was utter drivel, lol
Darrell
PJK
PJK
Darrell
 No worries Darrell. I agree with the rest of your post as well. There should always be a regulator in the line somewhere.
PJK
i had a look in snowy's today half the portable stove were high pressure, other half were low pressure the low pressure needs a regulator without it you may blow yourself up.
Dave S
iv'e lost my glass.
