Post Info TOPIC: Another generator recal
Recall of 6Kva generators
http://www.recalls.gov.au/content/index.phtml/itemId/1061639
While not directly concerning the RV field  it does show the problems!
It seems there is no end to the crap, that is coming in
Yes, fitted with a RCD, BUT it is NOT functional,. for a very simple reason :roll:
PeterQ
Sheesh !! It's not hard to fit a neutral link ..
Glad my little 2kva is completely covered in plastic or have I missed the point?
I'll get there one day.
HI
Yes, you have biggrin
PeterQ
Ahhhhh, thanks for the explanation ;)
Hi Tom
You do deserve an explanation biggrin
Even though your generator may have a full plastic case ..,That has nothing to do with with RCD protection
The Earth  of the 3pin socket/s will be connected to the Actual GENERATOR frame[ the GUTS that generates the power]
In reality it makes no difference to the SAFETY recommendations or how /why an RCD or RVD should be considered
 Perhaps your generator has a terminal marked "EARTH"?
Perhaps the Manual even suggests using an "EARTH STAKE"??
DO NOT connect that "EARTH "terminal to an EARTH Stake or to any other earthed structure, water pipe. steel building frame  etc
PeterQ
-- Edited by oldtrack123 on Thursday 7th of August 2014 08:22:54 PM
Men.. Equal potential bonding I guess if any earth ? To prevent live chassis condition ..
Thanks for the explanation, I'll just leave mine alone, it worked fine the other day for about 4hrs so I figure it's ok.
