SmartBar
Post Info TOPIC: Confusion Over Correct Unleaded Petrol To Use in 2012 Hyundai Imax
This Hyundai link says to use Premium Leaded in my 2012 petrol Imax (the Iload is the commercial version).
http://www.carshowroom.com.au/newcars/2012/Hyundai/iMAX/O6B12H
I also read somewhere that using Premium Unleaded (95 Octane) would give more kms per litre than normal Unleaded (91 Octane) and also more power, and the Imax was tuned for 95 Octane.
A Dealer also stated that I should use Premium (95) also.
However when I rang the RAC Tech Department they said they had nothing that said these were to be run on 95 Octane and 91 should be fine.   I saw a tradie in a carpark one day with a fully loaded Iload and he said the dealer he brought his off said to use ordinary unleaded (91 Octane).
During a recent country trip I refuelled with standard unleaded (91 octane) as 95 octane was not available at some town servo's).
Also bear in mind that there is a huge cost difference in the price of 91 and 95 (and even more for 98 octane).
Using both 91 and 95 I can't really notice any stand out difference in performance or fuel used, so am wondering what the hell!
Anyone got a view on this?   confuse confuse confuse
-- Edited by Vic41 on Monday 14th of July 2014 09:49:46 PM
Hi Vic, I ran the Prado on 98% for the last 18 months of it's life with me, unless I couldn't get it. Ran much better than 91% and better economy but not sure if it worked out cheaper over all.
My daughter here in the tropics runs on 95% and reckons her Camry runs much better than 91 or 98.
I was told many moons back that the high octane also keeps your injectors clean.
Why not run a 10% ethanol blend, save money and get a little extra boost.
Shell is 94Ron and United is 95Ron.
Don't know about the other brands, but the servo operator should (Ha Ha) know.
OJ
Vic, the telltale sign with 91 and 95 is wether or not you can hear the engine pinging. If it pings on 91, you may need to use 95. Had a chat with a knowledgeable person regarding various fuel grades. The bottom line from his pint of view was, using 98 around town is a waste of money. You only get value from 98 on highway use.
I have used ethanol blend in the name of 'green'. Whilst cheaper at the pump, you end up paying for it via greater fuel consumption and no noticeable boost.
Larry
Thanks Doug, Ozjohn and Larry.  Food for thought.
I was also told that 98 was overkill and a wast of money (the most expensive too) so have avoided that.
Not sure if I could hear any pinging as my hearing is not the best, flat out hearing the blinkers (wish they would make them with volume control so you could make them louder! LOL)
Very unlikely to hear pinging with fuel so close ie 95 and 91 especially with auto trans, which I assume it is.
 Thanks Baz, yes it is auto...blankstare
Vic41 you could fit a beeper to your blinkers if you can't here them.
Lance C
Thanks Lance, I'm just about beepered out, I have reversing sensor audible beeper (for objects) and outside audible reversing beeper (warning to others I am reversing), but worth a thought as I would be driving so a bit different to reversing....smile
You will not hear 'pinging' in any modern engine - most are fitted with "knock sensors" which detect pinging and instantly retard the ignition etc to stop the pinging.
The imax is designed to run on 91ron - not premium. Using premium will have no advantage and cost about 15c per litre more.
See this link:
http://www.redbook.com.au/cars/research/used/details/2013-hyundai-imax-tq-w-655896?R=655896&Silo=spec&Vertical=car&Ridx=1&eapi=2
This is not Hyundai Imax specific, but is a very good description of the petrol 'types' available and their usage.
One would expect that your Owner's Manual should be helpful in providing advice on the 'type' of fuel to use in your particular vehicle.
Perhaps the sticker under the fuel filler cap will be even more helpful.
http://www.caradvice.com.au/93272/what-fuel-should-i-use-in-my-car/
This is the link from my first post on the thread that says Premium Unleaded Rocky, but I am getting mixed messages on the subject, see the specifications here;  http://www.carshowroom.com.au/newcars/2012/Hyundai/iMAX/O6B12H
As I mentioned earlier not many small country servo's have Premium Unleaded so I have been using Standard Unleaded on my trips, topping up with Premium when able to.
Thanks for the tip and the other link John, it is very interesting. smile
Update:  As suggested I looked inside my fuel lid and is just says simply "Unleaded Petrol" it give no indication as to what Octane, but I presume 91.   My car manual says 91 unleaded or higher (95 or 98) but not E10 with more than 10% Ethanol and none with Methanol mix.
As said earlier car dealer workshop told me it needed 95 Octane, but the RAC said 91 Octane.
I will still keep asking around but in the meantime will probably just use 91 with the occasional top up of 95 for good measure.smile
-- Edited by Vic41 on Tuesday 15th of July 2014 06:53:34 PM
Late model EFI engines should tune themselves.. If its a hot day pulling some weight?
It may pay to change down..
I modern engines ping ?? There's a tune issue issue . Restricted fuel filter, thermo fans not working etc??
Thanks AK, nice to know! smile
Vic, did you look at the redbook link I sent?
See this link:
Thanks Denis, and apologies for not spotting it, I must have jumped a couple of posts.
RAC WA also use Red Book to give their opinion on fuel, they said 91 ULP also.  Mine is a 2012 model but I assume it would be the same.
This extract was from your link (for others info);
Fuel TypePetrol - Unleaded ULP
SeriesTQ-W
Recommended RON Rating91
Thanks Mate, that will save me some money!!! (very happy) biggrin
PS:  Just checked the 2012 Model using the link you provided, is the same as the 2013, Thanks again, Vic
Note:  Part of the confusion is this link which says the same model uses Premium Unleaded fuel, see;
-- Edited by Vic41 on Thursday 17th of July 2014 12:44:26 AM
 Just a final note.   Looking at the Hyundai Official Website, it just says the Imax auto 2.4 petrol uses petrol (fairly obvious I would have thought) but no mention of type of petrol or octane rating in their download specifications.
I rang Hyundai Head Office and they said just use what is in the vehicle manual, which is petrol 91 Octane or higher (ie; 95 or 98).  They also said ask your Hyundai dealer (well mine said Premium Unleaded, ie; 95) I told them this and also that the link shown at the bottom of my previous post says to use 95.
They had no answer for this but to say just use what the vehicle manual says (91) and when asked if it would cause any damage to the engine said no.
Talk about mixed information from different sources!   So as far as I am concerned I will use 91, more available and lighter in the pocket...
-- Edited by Vic41 on Thursday 17th of July 2014 12:14:28 PM
91 is being phased out in nsw..replaced with E10
So will 95 still be available?   And will E10 be safe to use in petrol engines designed for 91? confuse
(in my case a 2012 Hyundai Imax)
Still around in WA, haven't heard any rumbles about it being phased out here yet.
-- Edited by Vic41 on Saturday 19th of July 2014 10:06:48 PM
I told you so to get an Diesel van  Vic biggrinbiggrinbiggrinbiggrin
Cheers John
Well you are in WA Vic. I've ducked my head so you can throw one,,lol
Had my Transit diesel John......diesel ok but hated the manual 6 forward gears....furious
Ah Yes Baz.......WA......"Way Ahead" (not Wait Awhile like some believe!) wink biggrin
We run E10 in all our Ausgrid vehicles including IMax with no issues.. The fuel we use is Caltex.
Thanks AK, do they need any change in tuning or are they self tuning for the E10????
Yes they may go through more fuel if pushed on E10 let's face it work vehicles generally are!! ..EFI has sensors covering everything from air intake density, coolant, intake temps, tps throttle position, O2 sensor etc etc
Thanks AK! smile
