Post Info TOPIC: Test run of new auto Coupling and slider.
 Gday,The above has now done 2000k and 9 connections and reconns to the same.Absolutely the easiest way to go and no help needed ! The slider mods have worked a treat and as you can see by the side of the A frame scratches they are doing the job,and no noise at all . Very happy JohnDSCN0572.JPG
Looks good but I have a question: where is your breakaway cable connected to?
A friend of mine has ordered McHitch slider for his new Spinifex caravan.
Regards Chris
-- Edited by vanman on Tuesday 8th of July 2014 06:26:43 PM
Every one dies but not everyone lives!!!
Would make opening the back door to the Pajero doable. I have a Hyland hitch for that reason. The McHith is cheaper.
Mechanised Swaggies
Chris I had half a D clamp welded on to the tow bar frame so it is attached independant of the towing assembly and had that and the sliders certified by an engineer so that no bastard will give me grief .Neil ,its great mate so much better than my old set up that I had to modify the handle ,this one is about 50 ml clear of the door.John
And no 7 "D" shackles either. wink
Live Long and Prosper
MN Triton auto diesel 4x4 & 20' 6" Kokoda Tribute II XL Platinum
Looks a good unit.
Great to hear the good news. Thanks for sharing.
Cheers Jeff
Hi John
Please excuse my ignorance but where or at what point does it disconnect from the tug. It looks impressive and I must admit I haven't seen one before, you are certainly impressed by it.
Ashley
An interesting concept - and apparently very effective.
This will help you to understand - http://www.youtube.com/watch?v=31Q-i9RKseQ
G'day
I have just received am in the process of fitting the McHitch unit, and can only say that it is all that it is advertised to be. Makes coupling very easy, I can now open the Pajero rear door with about 30mm clearence, without the spare tyre lift kit. As I indicated, I am still in the process of fitting the sliders and the lift sections, but that is straight forward. I was able to use the one and quarter inch shank, as I have the same wdh as the pic above. I am very happy with the product and the way that the supplier answered any questions.
Looking forward to the road test very soon.
