Post Info TOPIC: Toyota Tarago Fuse box location. 1986 2.2 EFI...
Hi Friends, Can anyone tell me where to locate the FUSE BOX on a 1986 Tarago ?.
I have near torn the van apart looking for the thing !!.
Any help would be greatly appreciated, and save my Ulcers bleeding !.
Also any tips on this model  would help also.
Cheers FnOzi...
PJK
Used to have an 86 Tarago, trying to remember.
I think it was at the end of the dash board only exposed after you opened the drivers door.
Or to the right side of the steering column right down low.
There is a plastic cover on it and the cover matches the surrounding trim.
Hope that helps. I traded mine in Feb 2002 with 386,000 km and the drive train had not been touched.
PJK
Now that food has replaced sex in my life - I can't even get into my own pants!!!!!!
Hi FnOzi,
I think the fuses and relays etc are in the center below the dash. There is a panel at an angle facing down under the dash which covers them over. They get in the way of the feet of a center passenger.confuse There might be some others sprinkled around also for accessories. The cover has some information embossed on it regarding the applications. Hard to see the see the actual fuses if you are not flexible and cannot get down and look upwards ETCcry
Good luck Jaahn
PS Buy a manual on a CD from Ebay. Cheap as chips. Might be LHD though.
Hi Friend, you have no idea how much the information you gave me helped.
it was precisely where you said it was, and after almost giving-up on the job, it was found, thanks to you.
I owe you a beer some day.
Cheers again, FnOzi...
Hi Friend,
My apologies for the delay.
I eventually found it, and now, all is well on the fuse-blowing front.
Thanking you for your post.
Cheers FnOzi..
