Post Info TOPIC: Map based itinerary planner.
I'm looking for an easy to use map based itinerary planner/builder, need to be able to save and retrieve results so that I can add to the map and share results with others.smile
Santa.
Me too :)
See you on the road
Ain't easy is it? thought it would be a no brainer.
Google certainly won't do what I need, at least not without more messing around than I'm prepared to endure.confuse
Santa.
Try Googling Nomads Notes and see if that suits your needs.
Try this webpage as well. Memory Map
http://memory-map.com.au/mapping-software.html
-- Edited by Yuglamron on Monday 16th of June 2014 02:41:13 PM
-- Edited by Yuglamron on Monday 16th of June 2014 06:42:27 PM
I don't want anything GPS based.
Simply want a savable Windows based itinerary planner/builder.
Seems like a simple need, sadly there is very little available.hmm
Santa.
140 views! no success yet, seems what I'm looking for is not readily available.
Perhaps an opportunity for a PC savvy person to write a new program/application.smile
Santa.
Have you tried this?
www.travellerspoint.com/
Coachmen Mirada Owner
 Many Thanks, pretty much what I was after, lets me give friends a visual idea of where we plan to be over a given period.smile
Santa.
Tried that (traveller ) last night - pity I cannot make it follow the roads but the idea is good. Just wish I had registered, logged on, then entered all the places. My map has vanished in to cyberspace so have to start again.confuse
-- Edited by spida on Wednesday 18th of June 2014 07:50:25 AM
Its not meant to be a navigational tool Spida, its an itinerary planner,  perfect for my purposes, allows me to build a visual sharable map of planned travels, I have a GPS and maps to cover the actual nuts and bolts of the trip.
Registration is simple, as is building a map, very handy tool.
Santa.
I have been looking for a map so I can show where I have been - which is why I thought this might suit - and why I wanted one that followed the roads. I have input data again but find it struggles to find some places - Litchfield park & Pine creek.... to name a couple. Got there eventually.
Logged on last night but keeps getting stuck in the "saving" mode and I can't get past my start point. Tried twice again today but same deal so possibly an iPad issue with the program. I experience this on some sites.
Cheers Jeff
Some smaller programs are not design for fruit machines as they have to re compile the program to work.
They work with most programs as the programmers take that into consideration but if a small programmer writes for a particular market then they will often ignore the option to allow Apple etc to read properly.
It also depends on what language the programmer is using to write that program.
Brian
Thanks Brian.
Cheers Jeff
Has anyone found an actual program to do this, and not a website? It would be good to be able to do what is described offline.
 Not yet.confuse
Santa.
I have started using the trip planner on caravancaravan.com.au - really like it
