Post Info TOPIC: Dometic 2350 240V element
I just replaced the 240V element in our Dometic 2350 3 way fridge and found that it was very difficult to remove and replace. The element seemed to be very tight in the chimney tube and took a great deal of wriggling back and forth, with considerable upward force, to remove it. I expected it to be a snug fit, but not this tight. Is this normal?
Bob
Yep thats the way they are made as the heat from the element is transferred to the boiler tube by heat transfer through the mounting tube..
I have had them soo friggen tight I have had to destroy them to get them out..
oldbobsbus@gmail.com
Life can be a bitch, and so can removing a Dometic element.
Yep! They're tight.
OJ confuse
-- Edited by ozjohn on Sunday 1st of June 2014 02:14:38 PM
HI
And if the replacemet is not a tight fit ,it will probably not last long!!
PeterQ
Thanks guys.. yep the new one was also tight to fight.. not quite as tight as the one I removed, but to quote from Crumpy in the Hilux add, "its as tight as a snapper's" .. ...... and we all know that's watertight... wink
 Sounds like you're on a winner mate..smile
