Post Info TOPIC: Underbunk V rooftop Aircon
Hi guys,
I have recently purchased an 1993 evernew 21' caravan.
I need to install an Aircon as I'm heading (back) up to Darwin.
I was talking to a caravan dealer and mentioned that I was thinking of installing an underbunk Aircon, to which he replied that he'd never seen one and that everyone preferred rooftop models.
I had a mate a few years ago complaining that he'd had nothing but trouble with several rooftop models.
I'm wondering what your experience is ?
northernblue
-- Edited by Northernblue on Friday 30th of May 2014 09:09:37 PM
-- Edited by Northernblue on Friday 30th of May 2014 09:10:30 PM
I was thinking of installing one once but sold the RV before I got around to it so can't speak from experience.
I am surprised the dealer you spoke to had never seen one though, they have been around for years. For instance Truma are imported by Dometic for the Australian Market and many larger RV stores sell them among others.
http://caravansplus.com.au/catalog/product_info.php?products_id=6486
I have been told that the cooling only model (the one above is cooling and heating) is more efficient for cooling and is the better value, but others GN's who have them may be able to give you more info.
Here is an extract from another thread on GN found using the "Search" shown on the dark blue line above;
http://www.waeco.com.au/products5.asp?id=3039&catId=129&subCatId=131&subCatId2=-1
Or;
Truma Saphir (Cooling Only)
 http://www.waeco.com.au/products5.asp?id=3040&catId=129&subCatId=131&subCatId2=-1
Hmmmm......according to the links, the Saphir (Cooling only) is about $100 dearer than the reverse cycle Climatic confuseconfuseconfuse
The Saphir (Cooling only) is 2.4kw and the Climatic (Reverse Cycle ) cooling unit is 2.2kw but has heating also....
PS:  If you use the search as mentioned and type in airconditioning you will get more info on all types....
-- Edited by Vic41 on Friday 30th of May 2014 10:04:32 PM
The latest Air Command Ibis appear to be the pick of the bunch for roof tops. but bare in mind that strengthening of the roof will be required.
Under bed models A/C/s available are about at useful as tits on a bull.
have you considered a Domestic Inverter type Split System A/C as they work better than any of the RV models and are a lot cheaper?
Also the extra weight of any additions such as an A/C will form part of the vans Payload allowance.
Cheers, Ozjohn.
-- Edited by ozjohn on Saturday 31st of May 2014 08:01:04 PM
Have you considered a split system like they put into houses. I have a Kelvinator and I reckon it's more efficient than either the rooftop under under-bed its also quieter, uses less power and is cheaper.
See you on the road
Hi Northernblue
Air command have recently brought our an under bed model called a "Sandpiper". 2.2kw of cooling and 1.8 kw of heating.
It looks like someone has thrown a polystyrene esky under the bed. It has 3 outlets. An inside the van return air duct and undervan ducts as well.
It was the item the dealer "threw in" to seal the deal when we bought out 15ft poptop.
We've only done a couple of small trips but it seems to work very well. If I had a negative comment it would be that the lowest setting still pushes a lot of air, but I would rather have it over powered than struggling to do the job, and it's very quiet when you hit the off button wink
Live Long and Prosper
MN Triton auto diesel 4x4 & 20' 6" Kokoda Tribute II XL Platinum
Here are some price comparisons from one source, see;
http://www.dariocaravans.com.au/print.asp?action=search&query=conditioner
