Post Info TOPIC: Liquid Roof EPDM
Liquid Roof EPDM
Has anyone used or had this put on there caravan or motorhome roof. I have read up on this product but would like to hear from someone who has used it.
Thanks.
Have had our motor home done 12 months or so ago. Looks al very good. Had the guy in Albany do mine and very happy with the service. Mine apparently still had some moisture in the roof because after a couple of hot days it bubbled a bit in one spot. The installer came and fixed up no problem. When he put a small hole through water came out. Injected some more EDPM under top coat to stick down. Not cheap but a 15 year warranty is better than original. Much thicker than original Winnebago rubber roof.
Neil
-- Edited by woolman on Sunday 18th of May 2014 12:11:27 PM
Thanks Neil ,
Could you have done it yourself or is it not an option because of warranty.
Mick
I believe the warranty requires a certified installer to apply. To apply need to get roof really clean and dry. Must be kept dry for 2 or 3 days after application, can't have a night time dew either so needs to be under cover. I reckon you could soon learn the trick to applying. Not sure where you buy just the product but that is most of the cost.
I would/could not do it myself. Too many years of running sheep has buggered the back. Can't even get on the roof now.
Neil
