Post Info TOPIC: Itech dig tv finder
Itech dig tv finder
After having problems with my Itech did sat finder I rang Itech and somehow I changed the settings no
If anyone else had problems ,this is how you get the right settings.
On the model on the back be model d3.
main menue
find satellite
sat name should be itech D3  (forget optus C1 on sat list)
lo freq 10700
down freq 12487
symbol rate 30000
polarity v
dise  c1 .0 :  lmb 1
22k on  buzzer on
click exit then ok to save.
Hope this helps?
-- Edited by graham (chickenman) on Wednesday 7th of May 2014 03:29:43 PM
KFT
another good reason not to use Itek
The download frequency was changed last year to 12567MHz.
The sat you look for is optus C1
you only need 22KHz on if you are using a "universal" LNB if your LNB is a normal 10700 you don't need the 22 KHz on
DiSEq should be OFF unless you have an auto seek dish.
frank
Avagreatday.
Ket,I had it on that c1 ku and had no luck on that,the infoi have put upis correct as it only toolme maybe 1 minute to find the sat.
The info I have put up wahat I was told by Itech in Wa, and I cant dispute what he told me as it worked, maybe your thinking in Optus c1 ku as on analog?
But if anyone has the Itech d3 this is the correct setting I put above.
Or if you think I am wrong ring Itech in Wa 08 9472 720
att pic is my settings, and yes the buzzer does work.
-- Edited by graham (chickenman) on Wednesday 7th of May 2014 03:15:39 PM
-- Edited by graham (chickenman) on Wednesday 7th of May 2014 03:21:54 PM
Chickenman settings are correct for your sat finder d3  i hv same ...if I was wiser in hindsight would never have dealt with itech.more than likely opted for Queensland company who I know from others have received better customer service.good luck with yours great to have one.roy
HIGHWAYMAN
I put the info up as so many people who have the Itech dig finder  for Vast has it set on optus C1.
So I rang Itech in Wa , the guy was so helpfully in giving me the right settings and ive saved it in notebook.
I am not to argue but to help anyone else who had a problem like me and almost ready to hit it with a hammer.
-- Edited by graham (chickenman) on Wednesday 7th of May 2014 03:56:49 PM
KFT
No worries graham, you are searching for D3 not C1 then the frequency is most likely correct. I search for C1 and have no problems finding and locking on it.
you still do not need 22KHz on though-read my explanation and see if it applies to your LNB
same for DiSEq if you do not have a auto dish.
frank
-- Edited by KFT on Wednesday 7th of May 2014 06:50:39 PM
Avagreatday.
The Aurora system was officially switched off last year.
See this thread:
thegreynomads.activeboard.com/t57225200/satlink-ws-6906/
Here are the available channels, including several VAST channels:
www.lyngsat.com/Optus-C1.html
www.lyngsat.com/Optus-D3.html
www.lyngsat.com/Optus-C1-D3.html
Any channel that has an "F" in the "System Encryption" column is free-to-air. You can use these channels for tuning purposes.
Here is the setup information for the free VAST Info channel on Optus C1:
www.lyngsat.com/tvchannels/au/VAST-Information-Channel.html
Here is the setup information for the free Al Jazeera English channel on Optus D3:
www.lyngsat.com/tvchannels/qa/Al-Jazeera-English.html
Here is a list of "Free TV from Australia":
www.lyngsat.com/freetv/Australia.html
Optus C1 and D3 are co located (together) so its immaterial what you call it, its the transponder frequency that matters eg. 12567mz and polarity and simbol rate.
Itech could call it the Mickey Mouse sat, doesn't matter its just a name.
Looks like they have had a run of the popular SF500 meter done with their logo and called the sat by their name for a bit of free advertising (they probably need it) !
Same meter as Satplus and Access antennas, over a $100, straight from China $35 delivered.
brian
Brian, my was set to Optus c1 on my finder, when it found the satellite it show quality then ready to tighten up the dish it just go away and hard to find it again.
I have had sat tv since 2007 with the strong decoder, I don't call myself a expert but can set up on sat tv in like 5 mins as I used to take the decoder and a sm tv on a chair beside the dish till I found the green signal strength.?(On the strong it was app 94% but on dig tv on Vast it is mostly app 74%)
Upon that by ringing that guy yesterday he gave me the right settings and it took me about 2 mins to find the satellite.
He also mentioned that if the model number is d3 use the d3 settings like I have put up on top of this forum, but also said if its a 3d use the 3 d setting.
Also my lmb  on my dish is app at 7 o'clock, but varies upon which area you are in Aussie.
Also if you have a Pendopad tablet the power supply will fit into the satellite finder as it is 13.8 volts and all you need to do is to connect the finder into the lmb and plug in the power supply without connecting to the decoder.
-- Edited by graham (chickenman) on Thursday 8th of May 2014 08:58:40 AM
Master (of Mischief)
See this thread:
 dorian, thanks for all that info, I got the Satlink 6933 last week from Access Antenna here in WA, great company.
