Post Info TOPIC: 12v tvs
12v tvs
hi all this my first post,
we have a bought a caravan and the tv is only 240v, any recommendations where to buy/type  240v/12v,
also what amount of power would a 12v consume ,i have solar panels but not sure yet what size they are ,also i have 2x6volt batteries connected to panels regards ian
take your time and hurry up
KFT
Welcome scooner,
some TV sets have a "brick" style power pack that is plugged into the 230v supply and a lead from that goes to the TV this usually indicates the TV will run on 12v as well.
TEAC is one in the 19-22" sizes.
suggest having a look around the appliance stores as they will be much cheaper than a dedicated "camping TV" from an outdoors type store or caravan parts dealer
suggest also you use the search function on the top bar of the home page. Kogan TV's have a very poor sound system so some external speakers may be required for reasonable sound.
frank
-- Edited by KFT on Tuesday 29th of April 2014 11:14:31 AM
Avagreatday.
Have a look here Scooner
www.kogan.com/au/&;
get one that's big enough got a small TV myself big mistake would get at least 24 inch now
thanks kft will take on board your suggestions my ears are not what they used to be lol so will check out if external speakers can be fitted before i buy, regards scooner
thanks turtle 8  have had a look at kogan site very reasonable have to confirm voltage not all on site show if 12v but a good site regards scooner
sorry mate this ones are all 12 volt ,look in the 12 volt section down the page
www.kogan.com/au/shop/televisions/
-- Edited by Turtle 8 on Tuesday 29th of April 2014 11:55:36 AM
I havehad a kogan 22 inch on 12v for years with no trouble.They are good tvs with usb, hdmi, and don,t use a lot of power. Bill
My Techovision runs on both
we have a 22" , got it from Dicky smith but Aldi had them cheap a while ago. Simular to other posts on here 12v/240 v via a power pack , pulls about 60w and also has a built in dvd player
Dennis and Yvonne .
Retired sparky of 50 years.
JUST COASTIN`
We picked up a 22 inch CVA brand from "The Good Guys".
12/240 volt. Easy to read & use remote.
A bit over $120.
Bought a Dick Smith TV with a DVD player built in.
Found the remote a real pain to use.
Many TVs seem to have poor speakers.
We bought a waterproof speaker from Aldi.
USB rechargable & plugs into headphone jack.
About $30. Use it for TV, MP3 & radio.
Silicone rubber cone shaped. Very handy.
I have a new motor home that did not come with a TV or TV antenna (I have a 12 volt TV)
What Antenna should I purchase and where from?
Should I fit the antenna myself?
When purchasing TV try to buy the straight 12V lead, Most vans will have 12V output in them.. No point in running 240V transformer when you already have 12V..
We have 120 watt panels with two 12v 130 ah batteries .. We've NEVER flattened the batteries ..Yet !! TV hardly draws any current..
-- Edited by Aus-Kiwi on Tuesday 29th of April 2014 08:02:36 PM
thanks everyone for your knowledge,and time ,time to go looking regards scooner
It doesn't hurt to invest in a 12volt / 12 volt transformer to protect your tv from any surge, I have a Kogan all in one, tv,dvd, usb etc, works fantastic, but i run it through the transformer so that it doesn't get voltage spike, just straight 12 volt as sometimes the batteries can be charged up to 14 volts and a lot of electronics don't like that much juice. Cost me $39 from Jaycar.
laurieoz wrote:
 I am very happy with THIS antenna.
They are not very hard to fit but I guess it is up to you..smile
oldbobsbus@gmail.com
