Post Info TOPIC: Honda 2kva
Honda 2kva
I have been offered a Honda 2kva less than a year old not done much at a very reasonable price question will a 2kva run my air con
Neil
you are never too old to set another goal or to dream another dream
From my knowledge, and street talk, the Honda 2 kva is really on 1600. ?And yes We have seen them run A/c. But I guess that it depends of the make and model of A/c.
Jay&Dee
I think it might struggle.
NeilnRuth
KFT
I will second the motion from JayDee
It would be best to try it.
My Eu20i will run my Ibis A/C as long as nothing else is turned on eg battery charger, fridge(on electric), HWS, microwave. and the genny must not be on "Eco throttle"
hope that helps Neil
frank
Avagreatday.
My chinsese Honda copy runs my box aircon and the charger , plus the 22inch tv.It was only $317 on Fleabay. Might not last as long, but the price was attractive. Bill
A Honda 2kv will not run my Ibis Command Air Con nor would my Hyundai 3kva Genny, but I have now got a Honda eu30i and runs everything with ease OK cost a bit more but you buy. Genny to a job and if it does not doe that job why have it
Cheers Kay & Dave, & Penny
We went for the honda 3k. It runs the whole fifth wheeler with air con ect all going at once. Well worth the bit extra to have no worries at all. Great on fuel too.
We are not on holiday, this is our life.
thanks all now in a bit of a quandry as the jenny being offered is a similar price to a cheapy on ebay I have to have it
Neil
Neil
 I bought a cheap 2kva and would not run aircon. Just bought this one and it runs aircon with some power to spare.
 http://www.pinnaclewholesalers.com.au/remote-electric-start-silent-caravan-camping-4-4kva-inverter-generator.html?search=inverter%20generator
WOW I made it clickable thanks to GaryKelly....Wonders will never cease.no Ha ha...
Aussie Paul. smile
-- Edited by aussie_paul on Tuesday 8th of April 2014 11:12:33 PM
-- Edited by aussie_paul on Tuesday 8th of April 2014 11:15:24 PM
My Honda EU 20 will run our 11 year old Dometic 3253 A/C in 45 degree heat as long as ALL other appliances including 240v Charger are OFF. It will run for 5 hours with ECO throttle OFF and A/C Thermostat set to nearly Max Cold with Fan on No.2 Speed. This stops the A/C from cycling Off and the internal temp was approx 28 to 32 degrees and was comfortable and a lot cooler than Ambient. I was happy with both units performance under these conditions.
Cheers Kev.
Yes our Honda runs our aircon in 42 deg C hot day,,, we had a heat wave in 2009 in SA and we were on Eyre Peninsula.
How many watts is your aircon rated at, as that will give you an idea.
The major problem running an Aircon from the smaller Generators,
is the start Current required,it is only required for a short time,
but this is often enough to stop dead the smaller generators.
the running current is usually a lot lower.
-- Edited by johnno02 on Wednesday 9th of April 2014 01:51:34 AM
Retired Electronics Tech
Amateur Radio Callsign VK2CJO
Well done Paul, that link really does work, top marks mate. Ive just used it to have a look at that genny. You know when there was very little opposition Honda probably was at the top for quality but now i doubt if it deserves the adulation that some heap on the brand. I've got a lot of stuff bought online (cheap) that has given me great service over a long period. The question i've got for you Paul about that genny is "is it really as quiet as they suggest 30db at 4 metres" if so you have just solved my genny problem for me, thanks!
Friar
Friar
 Hearing aids in or hearing aids out Friar!!!!!!
I will take it down the paddock a bit and see what we reckon, and report back....
Aussie Paul. smile
Friar
 I don't believe that any internal combustion engine will produce only 30dB(A) at 1 metre even on idle let alone under any load and this would lead me to question their other claims.
See you on the road
Will cost a few more pennies but...the Yamaha 2.4 leaves them all for dead.....technology wise they are far more advanced than the Honda's which traded on their reputation protected by their patient...... for years......10yrs later....its open slather.
Rosco
The happiest of people don't necessarily have the best of everything.
They just make the most of everything they have.
