Post Info TOPIC: Our solar and battery...
When we bought our van we relied on the salesman to recommend size of solar panel. I now know we have a 100 A/H deep cycle battery and a 120 watt panel with a "regulator" of some sort.
Wondering how that compares to what you the forum members are using?
Aussie Paul. smile
Hi Paul, I have a 100ah deep cycle AGM battery with a 140w solar panel, ATM, so far so good.
I am thinking when I go on the road full time to up grade to 2X 100ah batteries and add another 160w panel ( to make a total of 300w) So charging should not be a problem. My regulator is a CTEC D250s Dual. Cheers,
                          A day without sunshine is like, well, night.
Hi Paul
we have two 120 ah batteries and two 95 watt solar panels with a 30 amp regulator we also have a 2500 watt inverter
we can just manage with this amount free camping we also carry a 4.4 kva generator
Dragonfly1
C Geyer
Is your 4.4 generater heavy to move around,I always like to make the 1st financial outlay the cheapest,
if I buy too small and have to upgrade then it works out expensive,if I do it right the 1st time it sames time and $$$$
Happy Camping
Graeme
I was always taught to respect my elders,
but it keeps getting harder to find one.
Our generator is a fuji and weighs 28 kg has a remote start and also key start it stays on the back of the motorhome
will run air cond microwave and whatever you want paid $510 on eBay very happy with it
Dragonfly1
C Geyer
Dragonfly1
 What size is your genset Cyril?
I bought this one here in Ballarat and fired it up this morning and ran the Aircon without reving its head off.
http://www.pinnaclewholesalers.com.au/remote-electric-start-silent-caravan-camping-4-4kva-inverter-generator.html?search=generator
Now need to sell the first one I bought on Ebay that was supposed to be 2 kva. Only produced 1600 watts!!!! $280 sitting in the garage. Would suit someone just needing to top up their batteries when cloudy for too long.
Can someone teach me to make links clickable please?
Aussie Paul. smile
Same generator with a different name you should be very happy with it
Pinnacle are a good company to deal with just bought a diesel heater from them
just finished fitting it and works really good
Dragonfly1
C Geyer
Dragonfly1
 Thanks Cyril, you have made my day... I am lucky to have Pinnacle within 5km of me. nod.gif
Aussie Paul. smile
-- Edited by aussie_paul on Thursday 3rd of April 2014 04:01:52 PM
Paul
I used to live in gillies st next to the train line where the centrelink office is now
in fact I was born there 75years ago
Dragonfly1
C Geyer
dragonfly1 wrote:
Paul
Dragonfly1
 AND you sat beside me when I played electronic organ at the Blue Bell pub....before the diso era eh?
Aussie Paul. smile
Paul
My father used to get kicked out of the blue bell pub at six o'clock every Friday And Saturday nights
 Dragonfly1
C Geyer
dragonfly1 wrote:
Paul
 Dragonfly1
 Ok, Cyril, that makes more sense. Just thinking of him the other day as we came past your old place out towards Cardigan.
Aussie Paul. :)
Hold left mouse down and run your cursor over the URL, then hold Ctrl and press C to copy the URL. Before you post your quick reply, click on Advanced Editor. You will see your message there but also the tool for linking the URL. It's the chain icon amongst the other tools. Highlight the URL again with the left mouse down and using the cursor, click on the "chain". A small window pops up. Place your cursor in the Link URL box. Hold Ctrl and press V to paste the URL to the little window. Then click on Target and choose "new window". Then click on Insert.
Gary
Paul
You seem to know me and, my family quite well what is your surname
Dragonfly1
C Geyer
dragonfly1 wrote:
Paul
Dragonfly1
 Paul Bruty
Aussie Paul. smile
Aussie Paul. smile
Oops, double post, sorry.
Aussie Paul. smile
-- Edited by aussie_paul on Friday 4th of April 2014 12:29:36 AM
Hi Cyril, the instructions for starting my new genset with remote are basically non existent. This morning I went to show off to the missus and I could not get it to start without going outside and use the primer bulb as there is not an exterior choke lever. The instructions say press the start button twice to start. I am not sure what the first press means, I assumed it activated a choke of some sort.
Any secrets I should know? Anyone else?
Aussie Paul. smile
Hi Paul
to start the generator cold 1turn on fuel  2. Open vent on fuel cap  3 pump bulb 10 times. 4  turn key to on position
start by whitchever means you choose
the first press on the remote turns the remote switch on second press to start
after using the remote and your finished using the generator make sure you turn the remote switch on the generator off if not the battery will go flat
hope this helps you
Dragonfly1
C Geyer
dragonfly1 wrote:
Hi Paul
hope this helps you
Dragonfly1
 Ok Cyril, thanks. I was hoping that I would wake up, grab the remote and start the gennie while still nice and warm in bed!!! and it would heat the coffee machine up!!! I don't lie my chances of my wife Eril going out in the cold to prime it for me!!!! wink.gif
I played electronic organ at the Blue Bell in the evenings when it was 10 pm closing around late 1970s. Your old man kept me company Friday and Saturday evenings. You were in cars I think and had the whitish house with the large archways facing the road. Your old man bragged about your success..
Aussie Paul. smile
Well, I guess I am a little disappointed that remote cold starting is not possible with my new generator..no
Never mind, it works well and was not expensive. More important to me is to be able to remote turn it off when using the aircon into the night..
May be a challenge for me, or the smarter people on this forum, to work out something remote to prime it. nod.gif
Aussie Paul. smile
Paul
i find that once the generator has been started it will then start off the remote for the rest of the day
if you forget to turn the remote switch on the generator off the battery will go flat in about a month
Dragonfly1
C Geyer
dragonfly1 wrote:
Paul
Dragonfly1
 Ok Cyril, ta.
Aussie Paul. smile
Aussie Paul. smile
 Hi Aussie Paul,smile
We have a pair of loose 80W panels and a pair of 130 AH, (old now say 80- 90) batteries.  The panels are only just enough if conditions are good and I can get a good full sun position to put them out into. I can set them up at an angle to get the most output.  If they were fixed flat on the roof it would not be enough.
So if we drive a bit we get by as the motor charges them. If we are sitting it's not enough if the sun is not fully out or the place is shadey. So I have bought a pair of 130 w panels to put on the roof and will see how that goes. blankstare Will keep the loose panels for poor sun times.hmm
cheers jaahn
