Post Info TOPIC: Jayco Clock ... Doesn't work! ... help!
Hello all, I'm looking for some assistance with my Jayco Heritage mounted clock as it does not work!
Is it battery operated ... If so, where and how do I access the battery as I cannot find it.
Can it be fixed?
Has anyone replaced it with something more modern or nautical? If so, how and what with?
This is the factory fitted unit, the model with "Jayco" branding, gold rim, Roman numerals.
We just bought this van privately and absolutely love it ... Just wish the clock worked!
Cheers - Weg.
DEBnWEG
1995 80 Series Land Cruiser
2005 Jayco Heritage
gently twist and turn the clock, pulling it toward you as you go- it should come out - ours was held in place by a flat rubber band. You can then replace the battery. We did not know how to get ours out until we found it on the floor after a few k's of very corrugated road - then all made sense - hope this helps. (we had a 2004 Heritage then a 2008 Stirling Outback)
Jenny and Barry
Hi Weg if you hold the the outer ring of the clock and twist any direction as you pull it carefully ,it will come away from the wall .It is battery operated,1 x 1.5 AA battery is what you need  .cheers Peter.
SOME  POLITICIANS  AND  BABIES  NAPPIES  SHOULD  BE  CHANGED  OFTEN FOR  THE SAME  REASON.
Woops - posted twice - sorry
-- Edited by villatranquilla on Friday 28th of February 2014 07:02:37 PM
Jenny and Barry
Blimey, I thought I'd read that before.....biggrinbiggrinbiggrin
                          A day without sunshine is like, well, night.
Awesome guys, many thanks indeed ... Now we have an operational clock!
smile smile
DEBnWEG
2005 Jayco Heritage
Master (of Mischief)
I was going to say, keep the clock and throw away the Jacyo biggrinbiggrinbiggrinbiggrinbiggrinbiggrin
OK, now I am ducking for coverno
Wombat are you looking to win this years stirrers award ???
Don't worry about him, dawg. There's one on every forum.
If there are no dogs in Heaven, then when I die I want to go where they went.
My girls are Misha, Maddy, Morgan and Muffin. RIP Jen, my princess.
RIP Molly, our dear girl who crossed the Rainbow Bridge 24/10/2016. A loyal and faithful companion.
I wouldn't have thought Wombats knew what Jayco's were fairly sure I am right
I'm still undercover biggrinbiggrin
