Post Info TOPIC: Request Info On Length black dump pipe
We have a Coaster Camper and it didn't come with a dump pipe for toilet tank, So wondering what length you find you need for most dump sites. The site I'm looking at buying it has 3M or 6M lengths. I've read that some have 2 lengths and join when necessary.
Thanks in Advance
Toyota Coaster
Allan
Yes the old bugbear....... Storage. My MH has a 2" cam lock connector and a tube which fits two 2.5 metre long  hoses of 2'' Dia. with various connectors to suit. I have a cam lock that has a 25 MM connector and have been looking at the Camec Flathose on a wind  up carrier. You can cut the 25 mm Dia. 12 metre hose in half and use a connector if you need the full length. Looks to be a better way to go depending on toilet type. Depends on your black tank connector. Most places you seem to be able to pull up right next to the Dump Point so 3 metres should suffice.
-- Edited by Yuglamron on Sunday 16th of February 2014 03:40:39 PM
Yeah mine is a thetford connector 90mm, I can get an angled adapter to fit but it is more the hose length that I'm wondering about. I might go with one 3M to start with and see what happens.
I have two tanks one each side so it would be a matter of empty one and turn bus around, Not much clearance under it neither. Might have to drive on blocks to empty.
Toyota Coaster
Allan
I have noticed some dump points are quite high. I have a very low outlet but luckily the rear of the Motorhome has airbag suspension I can raise six inches. Sometimes it's too low even then. For example the dump point at Ipswich Showgrounds Qld is too high for my outlet. Also the one at Gympie rest area on the Southside of town in  Qld is so rutted It's way too high for me to pump out.
Hope you get sorted out.
Thank goodness they invented removable cassettes, makes emptying a breeze.  (well, you hope for a breeze biggrinbiggrin)
Neil & Lynne
Pinjarra
Western Australia
