Post Info TOPIC: STONE DEFLECTORS
STONE DEFLECTORS
HI  WONDERING WHAT SORT OF STONE DEFLECTORS EVERYONE USES
LOOKED AT ROCK STOMPERS , ETC
HAS ANYONE FITTED OR USED THE CLEAR , PERXPLEX TYPE MATERIAL OVER THE WINDOW OR WINDOWS ON THE REAR OF TUG , THERE IS A SHOP IN MELB SELLING THESE TYPE WITH SUCTION CAP OR STICK ON TAPE , CURIOUS
THANKS GRAE AND DEB smile
Hi Grae and Deb,
I have not fitted one yet, ut received some interesting advice when asking about the black mesh type last week.  Be wary of the clearance for your jockey wheel, or more correctly for your hand as you wind the jockey wheel up/down. It appears that they cause real problems in this area if fitted too close.
Discovery 4,
Retreat Brampton
Hi Grae and Deb
I've just picked up some Polycarbonate sheet from Home Hardware .. it's thin .. clear .. strong and flexible ..
with it, I also purchased 2 small packs each holding (3) small stand-off plastic suction cups with a little wire hook attached ..
Trace/mark and cutout the shape of the back window from the Polycarbonate ..
From the stand-off cups, remove the wire hook attachment that is used to hold an object for hanging and discard ..
The plastic knob where the wire holder was attached, is what is pushed through small holes that are drilled in appropriate locations in the cut-out shape of the piece of polycarbonate ..
I have already prepared to do mine but currently preoccupied .. this deflector was built by one of the sales staff at the shop, and its all a one-stop-shop ..
let me know how you go ..
Jonathan     DMax & NewAge Van .. fulltime
Jonathon, any pics available?
See you on the road
Plendo wrote:
Hi Grae and Deb,
 Plendo, looked, but I can't find the thread. Do you have a link?
See you on the road
See attached pic,, sorry can't quite see all but you get the gist of it.
You can make your own a la my style,,, works very well pushes dust and water out the side.  Cheap option and never need to fit or take off.
Adjust to 50mm off ground (or max suspension travel so it doesn't "bottom out),,,, no stones have hit the van so far as I can see.
 Unfortunately not sorry .. haven't put it together yet ! but when I do I will get some pics ..
