Post Info TOPIC: 2x60watt soler penels
Hi all
i have just bought 2x60 watt second hand panels with a cmp12 regolator will this reglator work with one panel or has it to be conected to the both to make it work
cheers snap
-- Edited by snap1946 on Saturday 5th of October 2013 07:36:42 PM
snap1946 wrote:
Hi all
cheers snap
 Not familar with the term CMP12, does the 12 indicate that its a 12 amp capacity?
If so it will handle both or just one if you wish. The main point to be sure of with any system is that the regulator is capable of handling the max amp output of all panels attached.
JC.
not sure it says cmp12     12/24v 10amp
Snap
CMP12 is a common regulator. It can be used with 1, 2 or more panels as long as the total input current is less than the rated 10 amps. With the panels you currently have there should not be a problem. Less panels mean less input current to charge the battery but will still work.
justcruisin01 wrote:
snap1946 wrote:
Hi all
cheers snap
 THANKS ALL FOR THE ADVICE
-- Edited by snap1946 on Sunday 6th of October 2013 06:33:22 AM
Thru the magic of Google......
.. Lots of results for CMP 12
... This is from the first result that I got.
Hope it helps.  G
http://www.jutasolar.com/en/product_more.asp?id=1185
Model
CMP12 6A
CMP12 12A
Max. load current
6A
12A
Voltage Drop
<140mv
<210mv
Rated Voltage
12/24 V auto
High Voltage Disconnection
13.7V -27.4V
Low Voltage Disconnection
10.5V -21.0V
Low Voltage Reconnection
12.6V -25.2V
Temperature Compensation
-3mv//cell
Max. own consumption
20mA
Biggest connection terminal
2.5mm˛
Size
102x45x107mm
Weight
0.168kg
DRAWING
©  Harbin Hopeful Star Co.,Ltd.  www.jutasolar.com  ICP08000351
Website producer group :www.hiwebsite.net
