Post Info TOPIC: Dining table removal
We would like to remove the dinette table in our new Avan pop top....  can anyone advise how the base comes apart from the floor? We have removed the table top OK but are unsure how to remove the round metal base. Any help would be appreciated.
biggrin
Mine unscrewed - a ring in the base was the top of a long screw.
Mine was screwed down so removed screws, checked underneath and found the screws had come though under a little so filled the holes with a sealant, so worth checking.
There are many table types in vans. Here a few Some of us (most) do not know what is in your van. However we do now how most tables work. Is it a wineglass type? If it is then take the leg out of the base piece. You will then see a screw that you can remove and then lift the base out (you may have to use pliers to shift the screw.)
