Post Info TOPIC: Correct install set up for Ctek D250S Dual charger please.
Hi,
I will install a Ctek charger, and would like to know what cable size members are using. Mine will be fitted approx 1.5 metres away from my 2 batteries. I know the wiring should be "big", but what size do I order ?
The other issue is whether inline fuses are needed. I have seen some installations with them, but notice the Bainbridge Technologies site has a video which makes no mention of fuses. What do members do ?
Thank you for your advice, Barry
Hi Bazzzz  ,know bugger all about wot you are talking about, !!But,!! im sure you are very excited about it,,,,,,,,,,,,,,,,,,,Billeeeeeeee
Simple is
       Beautiful
 Very constructive response.
Regards Jim
I would suggest 6B&S cabling as for the fusing it may be required near the battery.
Where is the charger situated? Check out the video although it only explains the functions.
http://www.ctekbatterychargers.com.au/ctek-d250s-dual.html?gclid=CMjisa2e9bkCFUpZpQodGWQAxQ
Regards Jim
The user manual which can be downloaded from the site given above gives cable size. I looked at it a few weeks ago but can't remember the sizes off the top of my head.
Bryan
I think billeeeeeeeeee has been using the sacred herb again when writing his responce to the question.........very constructive.
  Thank you  Patrolst, always ready to help where ever I can, !!But,!! may I add this, we are blessed by having Gerty, our very own dog whisperer on the GN, !!She,!! is a wealth of knowledge,,, and may I add , a very excited Lady,,,,,,,She is more than happy to help,,,   see you all out there in the play ground........,Billeeeeee
Simple is
       Beautiful
.?? 2 posts and neither makes any sense. Why bother!!!
6mm dual is what I used and it works well
Why not, a sence of humour helps.
How are those responses answering Barry's question???no
