Post Info TOPIC: UPDATE ON UHF COAX CABLE JOIN
You might remember last week I asked can you join the said cable and do you loose in signal.
Well, a join was not needed after all that as I found some cable entering through the firewall on the passenger side, after further investigation I was able to feed the coax along side the other cable and in behind the glove box, problem solved. At the end of the project I ended up being able to reduce the length of the coax and still have a bit to spare, now about 70cm shorter.
Job done and dusted.
Good on you uncle Doug
Cheers John
Thanks John. Must have been because there are no you know whats around me here. biggrin
biggrinbiggrinbiggrinbiggrin
 Doug, somehow reading threads around here I just wonder if the "whats around me" relate to a furry thing/being or to the genteel fairer gender types.
Just be pleased your coax is fixed and sorted, unhindered in process.
