Post Info TOPIC: need advice on installing a hot water service
hi all I have just purchased a truma 14 litre electric hot water service these are made by dometic I want to install it in my van and was wondering if anyone can give me advice on installing it I have a position under a seat and wanting to set it up so it can be run from a 12v pump or town pressure when in a caravan park
roy and mia (spalas)
if its not broken don't try and fix it
Evening Roy, we have a 14L Truma gas/240v 12v pump/mains, installed in our Kea.
Have never had a problem, in fact we find it an excellent unit.
However, many do have major problems, to the extent they have renamed them (Trauma)
The only difference I can discern are that a lot of the problems seem to occur with home installations, the plumbing/wiring and gas fitting look to be quite complex, draw from that whatever you like.
I'm pretty handy but this is one job I would have done professionally.smile
Santa.
the only difference is this one is a 240 volt one don't have it yet so don't know any more about it I have purchased from goldstreamrv I think it is only 240 volt no gas fitting according to a caravan place around here they said that these are a pretty good unit from what I can see without the gas connections it shouldn't be that real hard now it looks like all the piping is hoses I was thinking of copper but it looks like I don't need it
Hi roy and mia,
All I can say is measure twice and cut once as the positioning has to be correct.The ports are all labelled as to hot and cold so it is not too difficult to hook up. That is, providing you have the directions.
If they haven't given directions go back to request them. If you have them and its all Double Dutch, no explanation from any one will help, as all a person can do is quote the directions.
On the plus side, mine is a gas only model almost 10 years old, and has given no problems. These Things don't need the dreaded anode's either and that is a saving of around $300-00 over 10 years.
Santa, Yours has twice the room around it that mine has, and I am sure going to have a job removing it if mine ever blows up.biggrin
Retired plumber & Plumberess
 2004 Toyota TD LC
A'van Tayla 17'6" Caravan
 Lets hope it never does.biggrin
Santa.
Best advice on installing something that runs on gas an electric is take it to a licensed installer
-- Edited by NeilandRaine on Wednesday 4th of September 2013 10:39:32 AM
Mechanised Swaggies
Wait and see if it has some basic instructions ,then remember that it is req,d by law if it is to be used for purposes other than W/Machine and sink the water must be tempered.
our van doesn't have an ensuite so water wi8ll be used for washing dishes and a bucket full for the shower in the shower tent where we control how hot we want the shower and yes I have the instructions and all fittings except the 12v pump and a non return valve and the piping looks very easy to plumb it in just follow the diagram
jonno here. i have one of these. works great.
keep in mind when using on mains pressure you may need a pressure reducing device so you don,t burst it
