Post Info TOPIC: Anyone recommend a tick killer ?
Used to pull grass ticks from dogs with tweezers, and drop them in some Diesel in the bottom of a jar to definitely kill them.
-- Edited by Sheba on Monday 2nd of September 2013 07:23:12 PM
I've been using Advantix on Fang and so far, on ticks.
Adopting a suspenders & belt approach I was wondering
if anyone had a liquid or whatever that I could put on a tick
if I found one on our dog that would kill the tick outright.??
Get some fine-pointed tweezers and pull it out Chopit. There are a few things people say will make the tick detach, but my experience was that the only thing to do is simply pull them out. If its been there a while and is getting big, it will be quite hard to get it out.
I HATE ticks!!!
Cheers,  Gerty. ... at home
Hi Sheba I spray my dogs Permoxin mix with  Methylate Sprits ( Dry's quicker) daily as well as daily searching. You can also wash there bedding wih it.Hope this helps.
Braggabb
I use advantix on my dog.
As soon as spring hits it has to be used every two weeks.
This can be an expensive thing so we buy it online. Much cheaper than buying it from a vet
KathnDave
Don't Worry Be Happy
Thanks for the comments.
Yes, I buy advantix from Ebay.
Much cheaper than the vets.
While at a swap meet recently I found a pair of curved artery forceps.
I think they should help get ticks out that make contact.
Gentle grasp around the head and pry up as you would with a claw hammer on a nail.
I had heard elsewhere that acertone ( finger nail polish remover ) on a tick does the trick.
That stuff will kill anything so I guess it would kill a tick.
We live in a high paralysis tick area. In tick season we put Frontline on our girl every two weeks. On the odd occasion that she does get a tick I literally drown the tick with liquid "Tropical Rid", leave it for about 10 minutes and then remove it. According to our local vet the tick will start to remove itself and then die making it much easier and safer to remove it.
This method works on humans as well.
Another important thing to know about ticks is that they screw themselves into the flesh in a clockwise motion so when you are removing them you should pull them out in an anti-clockwise motion. This way you will have a better chance of getting the head out. If the body comes away from the head the tick can still keep injecting venom.
Really interesting about the clockwise thing.
I have just read elsewhere a method supposed to be effective.
Soak a cotton bud in liquid soap.
Swab the tick for 20 seconds or so.
The tick withdraws and can attach to the cotton bud.
May be worth a shot.
I investigated this gadget, might be worth a try?
https://miteyshield.com.au/
Hmmm. Intriguing.
Have you used one ?
I would like to find some independent results.
I'll do a bit of sniffing about.
Thanks for that.
I picked up a leaflet at the local chemist, and was hoping that the personal one was effective against mosquitoes, so asked the chemist about them. He said they'd had good feedback on the pet gadget, but they only work for ticks, not other insects. Has something to do with the mega Hz range at which the critter can hear.
Any means of keeping the critters off ourselves and our pets without using poisonous chemicals is a good thing!
Thanks for that.
Interesting.
Another good trick used by some dog breeders is to have a jar of Vicks Vapor Rub handy. Put a dob on the tick and soon it will back out of the dog. Friends of mine have done this for years
Hoping everyone has a pleasant and safe journey
all the best from
Liddle
that's interesting. Just might go and buy a jar of Vicks
KathnDave
We used to use Vicks to repel leeches... you put it on your legs/ankles.
OoH. This has got interesting.
Thanks.
Get on to Vetnpet web site, you can get all or at least most of whatever vet stuff you need on line and have it sent to you at wherever you are staying!
annie
Connor - Whippet
Ciaran - Whippet
Annie - after my 2nd cup of coffee I'm almost human!
Together we are pawsaroundoz!
Nail polish remover dabbed on the tick will make it let go, and fast! I suspect metho would do the same.
Geoff & Jennifer
Red Hat Queen and her Royal Consort
Coaster - "Priscilla 11"
"If you haven't grown up by aged 60, you don't have to"
