Post Info TOPIC: gas fridge
gas fridge
good afternoon
we are back from our trip  to the tip we did plenty of free camping so our dometic  fridge was running all the time on gas and the last bottle did not last very long
how long should last a 4.5 kg bottle before we run out of gas ? confuse
thank you
GG
boxing kangaroo
I get 6 days running day and night.
i get 9 days up north . i have fan pushing air in on bottom vent & 1 extracting air out on top vent.
Jeff
Living a life long ambition
It very much depends on the ambient temperature as in hot weather the fridge has to run for much longer periods to keep cool
Depends on the size of the fridge, my 105 litre fridge freezer runs 3-4 weeks on a 9kg bottle.
Got to keep moving and as Hippocrates the modern medicine guru once said "Let food be thy medicine and medicine be thy food
My rule of thumb is 1 lb of gas per day, ie 4.5 kg equals 9 days.
do gas bottles run when your driving?
or does fridge go on 12 v for that ?
The Drewsterz my band site
Milo Online  my personal site
It shouldn't make any difference what size the fridge is, what the ambient temperature is, or if fans are fitted to the rear of the fridge.
The burner flame remains at a constant height (& Heat).
The fridge temperature is controlled by altering the flow rate of the gas, not by altering the height or temperature of the flame.
Cheers, Ozjohn.
-- Edited by ozjohn on Wednesday 28th of August 2013 04:31:19 PM
we do not run on gas when  driving
 fridge go on 12 v
GG
boxing kangaroo
its not recommended to run on gas when driving
peter m
Hi John
To the best of my knowledge in the fridge I have, the temperature of the fridge is controlled by the one thermostat for both gas and 240v I don't know of any valve in the refrigeration system that controls the flow of the refrigerant in an absorption fridge.
David
Cheers, Ozjohn.
the ambient temperature definatly affects the eficcency of the asorption fridges. The use of fans is to extract the exhausted heat away from the enclosed cabinet area which improves the the cooling of the external surfaces of the the enclosed installation. I also try to park with the fridge side of motorhome out of direct sun.
cheers Jeff
