Post Info TOPIC: Has anyone had any thing to do with this device ?
What is the PowerPot?
The PowerPot is a thermoelectric generator, so it converts any heat source directly into power that charges your USB handheld device. Add water to the PowerPot and place it over a heat source. Plug in your device (don't worry, the cord is flame-resistant!) and it'll charge just as fast as it does from a standard outlet. Heat the pot over a stove, campfire, wood stove, propane/butane heat source, home range, or even a hot spring! Perfect for backpackers, hunters, and zombie apocalypse preppers.
The PowerPot is waterproof, flame-resistant, and extremely portable--weighing in at just 12 ounces! Unlike solar panels, it works anytime--even in bad weather, at night, and indoors! It's more than just an iPhone charger--the PowerPot can charge any smartphone, GPS navigation, GoPros, digital cameras, lights, headlamps, radios, water purifiers, etc. Wake up to a hot cup o' joe and some extra juice to your electronic devices, all provided by the PowerPot. Keep charging.
The web page I found this on www.zenimports.com.au.
Regards Herbie.
Time To Sleep Later In Life.
That's not the correct link. Try this one
I reckon it would take quite a lot of gas or other fuel to charge your phone or other device.
First up, no offence to Peter I've seen lot's of others do this to when adding a link.
When adding a link it's nice to use the drop down box and set target as 'New Window', that way clicking on the link doesn't take you away from the forums. Like this :)
For those interested the html code would be this: <a href="http://www.thegreynomads.com.au" target="new window">Like This :)</a>
Now back to business...
Looks okay, 5V @ 1A is pretty beefy and plenty enough to charge mobile phones and the likes, even compact cameras that are rechargeable.
It would be interesting to know how hot it has to get before it generates the rated 1 Amperes.
Do you know how much it costs?
If it costs more then say $60 you might be best off buying a small 20 Watt solar panel that comes complete with regulator, such as those sold at SuperCheap Auto - I have one of these. Not only will it charge the phone, my scanner batteries - it also will charge the vehicle battery. I can confirm it takes approximately three days to charge a battery from dead flat to a point where it will start the vehicle, an extra few days camping wasn't such a problem. Whenever I stop at camp I always connect the solar panel, I purchased a cigarette lighter extension lead, one end is a female plug (like what's in your car) to alligator clips which I connect direct to the battery.
I also use another smaller (fold out model from Jaycar) solar panel to charge 7AH SLA batteries, I can't remember the exact wattage of this panel, but it I think it is 10W or less. Plenty enough to charge the SLA over the course of a day. I also have an external regulator rigged up to this to ensure the voltage doesn't go high.
Stewart
www.vkportable.com.au
www.forums.vkportable.com.au
 With respect Stewart, Peter has it right,, it so simple to add the link and access it.
Just right click Peter's link and click open in anew window, you stay on the forum and open in another window,,, best of both worlds.
Cheers Baz
Just found the price for this and I do not think they will be selling many as recommended price is $269.95.
Cheers Baz
True, although if when adding a link in the box that appears (where you place the address) click on 'Target'  and select 'New window' the viewer does not need to right click as you say as it will automatically open in the new tab in your browser. The standard with almost all websites these days is to have links open in a new window (tab) so as not to take the viewer away from the main site.
It was simply a suggestion, different people like different things - I prefer to be able to click a link and have it open a new tab rather then take me from where I began to somewhere new.
Stewart
Seems to be a thermostack or something.
Thermocouple two metals when heated give off electricity ..
www.msm.cam.ac.uk/utc/thermocouple/pages/ThermocouplesOperatingPrinciples.html
Still not worth almost $300.
