Post Info TOPIC: Winegard Wingman
Winegard Wingman
Hi CC, Bundaberg is (was) renowned for lousy TV reception. They are now digital so where you were lucky to get 2 channels you can now get about 17 with a wingman. Long story short while there, this year again, I tried everything to get all stations to no avail so I went shopping for the Wingman extension on a money back guarantee, I did but no different. Then tried the new Sensa I think it is that is supposed to pick up both horizontal and vertical, again on a money back guarantee and no good. I even dropped a pin out and made the Wineguard into a vertical but still no change. The guy on the site next to me swears by the Explorer RV antennae system and he was getting all channels which for Bundy is magic. He also said he hasn't been anywhere there is a TV signal that he hasn't got the same channels as the locals. Convenience wise the Wineguard s great but don't expect to get signals everywhere you go. Just another perspective.
-- Edited by Legendts on Sunday 25th of August 2013 08:38:11 PM
Cheers Jeff
Just looking for some info on the Wingman
are they worth the money they ask for
Who has one and do they make an difference to your TV setup
Thanks look forward to hear from some members
Cheers John
hello john
i was getting interference, as i moved around my camper i would lose signal, turn on a light lose signal, all was good before the wingman as long as i was standing up inside in the dark................
since the wingman i haven't had a problem.
was worth the money for me
hope this helps
happy Travels :-)
http://livingthedreaminoz.blogspot.com.au
Baz
Hi John my answer to your question is YES and NO. I fitted the Wingman to the Coromal due to poor digital reception even out the front of the house were the van is parked, I was flat out getting any channels. Anyway after buying the Wingman and fitting it (it's really easy to fit) I could not believe the difference in the channels ended up with 34 digital channels. Now in saying that we have just returned from being up through the centre and there as you probably know some places are still on an analogue which is fine as we could still watch some TV. When we could get digital it was still very pixilated and I even purchased a signal strength meter so that I could rotate the antenna to get the best result. I do believe though that as the digital service improves I would imagine so will the quality to caravan setups. After returning from our last trip I ended up trading in my Coromal and I took the Wingman off and kept it thinking that I could put it on the new van, but have been informed that the new setup will have the new Winegard antenna so will have to wait and see what they are like. Sorry to ramble on a bit but hope you find the info handy anyway.
Gaz ,Rox & Ruby :aka C1,2&3
TAJ
HI CRUISING CRUSE  was up at bundaberg last year  bloke next to us could not get channels
                                 put one on and was okay.. had mine for years
                                 suenray
Our has been great too ,I thought it was a bit flimsy but it stays on all the same .John
John, think it is all a gamble or pot luck. As for Qld you have the signal in vertical & horizontal. Found this in Bundy many yrs back, had the old H/Wander stick, couldn't get anything seen one vertical & there is every thing.
M<eet people out at the Dickabram bridge, they had the new Jack ant, mounts onto the wynn guard system, they had all ch's there & we only had a couple with the dick smith special. Bought the Jack when we got to Gympie $105 & only tried it when we got to G/Coast, not a fair test but had ch;s that I had never seen.Comes with 240v booster, pole or w/guard mount.
Have now mounted it properly so see how we go next trip.
JC.
Hi all;
       I have been installing television antennas for the last 30 odd years , both domestic and commercial and have seen it all. As for the mobil caravan i have looked at and found that, yes this type or that type of antenna will work the best, when it comes to your own set up all the salesman wants is a sale and at any cost and will tell a pack of lies and mixed in with a bit of truth just to confuse the poor fool that has asked for a bit of advise. So you end up with some thing that resembles some thing that looks like it belonged to nasa or even came off the space shuttle, and the thing still does not work. But it worked in the shop, or were told it was the correct antenna for the area / or is desighned for the caravan.
So you go to a nother so called antenna teck and they sell you a nother piece of electronic gear, the amplifier, that is suposed to solve your particular problem and maybe it does work , and then maybe it doesn't work. But you pay your money, wife unhappy as you have just spent a nother couple of $100.00 and it still does't work , baa, hum bug and all of that rot. So were to go now may you ask. ?????
Well you could go down the parth of satillite television, but this has also it's own set of rules that have to be obeyed or you still do not have any telly.
So what does one do, well that depends on how deep are you pockets are and whether you are technicaly competant or not. Are you willing to spend a bit of time and do a bit of reserch, have a good understanding of electronics and know how to read a compass and finally know one end of a piece of coax cable from the other. Oh and a couple of other things do you know how to read a satillite meter ( and not the little $60.00 special that some companys have ) and finally learning how to set up a satillite can be good ground's for divorce. So haveing had all those years at the coal face and sold and installed antenna systems , what have i have ???
Well over 2 years ago i purchased a Vast system and at the time there was only one on the market and that was a 240 Volt only decoder ( i use a small 12 Volt to 240 Volt inverter, just for the satillite receiver ). I also use a second hand dish and lmb that lives on the draw bar of the caravan when we travel . At home the caravan is pluged in to the power, one to keep the house battery charged and also to keep the Vast receiver powered so as to get it's updates . I also have a second dish and lmb on the roof of my house and all that does is feed the receiver in the caravan. so i never have a problem and the caravan is al set to go at a moments notice.
Well how does it go, you may ask !!
Well i've never had any real problems over the last 2 odd years. In May 2013 we traveled from home ( Mildura ) to Dawin and back . 8300Klms over 6 weeks. Both free camping and in caravan parks and even had a few people come up to me and ask if i had television and could i have a look at there set up , cause i can't get mine to work. Also a good  happy hour subject.
I have just completed a14.000 km trip around Australia ,I have a winguard antenna with the wingman I found it wasent worth a pinch of goat poo, at Bunbury WA I bought a Happy Wander HW DT8 ,it is the best antenna I have ever had,in the rest of our trip I think there was only one place I couldn't get most of the channels available in that area,this antenna has a signal finder and booster to go with it wich I didn't have until I got home,the antenna without the booster did a great job I really recommend this antenna,my brother inlaw wich travelled with me has had a early model Explorer antenna with a booster ,never failed to get TV reseption where ever we were ,and we were in some remote area,s.
Lance C
There was a Wingard on the van when we bought it. We aren't addicted to TV, so we aren't upset at places where we don't get a picture, which happens occasionally in remote or hilly areas. But mostly its fine, it lives on the roof, no pack-up difficulty, we're happy.
Cheers,  Gerty. ... at home
First of thank you all for your reply's
The Tv is not that important to us to spend 600 plus dollars to have an picture with Sat setup
but some times I like the see the news
so i like to spend some money to get it working as we had the same problem as Jim ( Just Cruising ) at the bridge
I think going by what the majority says here it is a good thing
I saw one for sale in the New Caravan & Motorhome mag on page 101
the asking 44 dollars ( Fair price or not ) free freight
www.amazonoutdoors.com.au/
Cheers John
Cruising Cruze;
                     Hi $600.00 for a satillite set up, that 's way to much money. I payed just under $200.00 trade for my Vast receiver ( retails for about $250.00 ) and i use a old Austar dish and lmb, this i purchesed from the local recycling yard at the tip and cost me the grand sum of $5.00. Now all i needed was a trypod stand to be able to set the dish up on the ground, and that stand costs trade about $65.00 ( retails for about $80.00 ). RG6 Quad coax cable, the good stuff and needed for digital and satillite television. Coax cable, well RG6 anyway i used to sell for $2.00 per meter and i would also throw in the 'F' type connectors as well, and even make up the leads, so about $20.00 ~ $25.00.
The only other thing that i would need is a good satillite meter and start from about $100.00. and the meter comes with a little compass.
So about $440.00 all up, yes i here you and still you might say dear. Well mabe, but when you weight up what it has cost you for a so called digital antenna, amplifier, teloscopic mast and the bracket to hold the bracket on the draw bar of your caravan, coax cable and this type of setup would cost about the same amount of money, AND no guarantee that it would work in all areas. This is why i when over to the Vast set up and i used to have a good digital antenna and amplifier and mast on my earlyer caravan, and i had problems when we went away at xmas time. I realy cracked it one year, here's me i have worked in the electronics industry nearly all my life and i was haveing problems due to the area and the polarity of the signals that i was trying to receive.
Yes the vast service can be frustrating when you are learning the procedure for the setting up of the dish and even trying to get the coordinance right.BUT once set up correctly, you have all of the digital channels.
Now i hope this helps
Wingman worked for us,,, as a matter of fact I about to set up Sat dish today and decided to check local TV,, all OK near Miles QLD.
Better picture for us so far, but new Topfield box seems to be creating some interference. Old cheap $30 box had better picture but left it home (bought Topfield so we had HD to record)
