Post Info TOPIC: Tank safe
Tank safe
Read the instruction and ingredient label you may be surprised what's in it and already have it in the shed under a different name . If the label doesn't tell you what you want to know ask the company for  MSDS which they are obligated at law to provide .  There are only a couple of chemicals that are permitted  in potable water supplies  so be careful of the dose rate and the method of dispensing it , in concentrated form these chems can be a bugger to handle safely.  Beware of bucket chemistry methods
-- Edited by Wombat 280 on Wednesday 7th of August 2013 09:17:49 PM
-- Edited by Wombat 280 on Wednesday 7th of August 2013 09:18:52 PM
Has anyone heard of a product called " Tank Safe, a rainwater tank purifier. It's a solution that you put into your water tanks and it claims to kill germs, viruses and other pathogens. It last's for about 2months and only needs a small such as 65 ml in a 1000 L tank. You would only need a small amount in say a 80 L tank. Looks like it comes only in a 2L bottle but will need to follow that up.
If you have heard of this product or you know of someone who has could you let me know as I'm interested. As we all know bad water is bad news
Thanks
briche
The Master
You can do the same with Bleach. My brother puts it regularly in his tank and I have heard of numerous others.
When up at my sons in Biggenden I asked at the hardware store if they had anything for his tank. They hadn't heard of anything I could use so we reverted to the bleach as well.
It was only about a cup per tank (40,000 litres I think)
Happy Wanderer
Don't worry, Be Happy!
G'Day Briche, It's probably not what you want to hear, but I'd worry that if it is that powerful then what does it do to you when you drink it. If the product you talk about is called Aqua-safe and as you say it's dosage is 65ml for 1000litres of water, then for your 80 litre tank you'd need to add about 5ml or a teaspoon full. This amount could only be added to a full untreated tank.....what do you add when you're not sure how empty the tank is? Is overdosing dangerous?
We've never had bad water but maybe we've been lucky and I must say that I've never heard first hand of the consequences of bad water. Most of out lives we've drank untreated tank or bore water with no problems.
Regards.
Thanks guys for the reply's. I was notain't ending to use it more of trying to find out more about the product and or people's comments about this particular topic. All you comments duly noted and taken on board. Thank you all we will research the topic more. Like the idea of bleach much more within the understanding of the topic.
briche.
Instead of bleach, which seems to have detergent in it nowadays, you could try Milton. Its used to sterilise babies bottles, then according to directions use them without rinsing so it must be safe. Its likely to be more expensive though,
Cheers,  Gerty. ... at home
