Post Info TOPIC: Simplified Camp Chores
To take the work out of maintaining your cast iron cooking equipment
If you leave the left over cooking grease and oil on your equipment it will form a layer of protection against rust.
But if you like to keep things nice and clean, try placing a layer of aluminium foil on the hotplate first for a easy clean up.
When finished cooking just throw away dirty foil.( bin it not throw it into the bush)..
Time To Sleep Later In Life.
Foils good, baking paper is better. Much more easily biodergraded
Kevin, Vic.
Intelligence is knowing a tomato is a fruit.
Wisdom is knowing not to put it in a fruit salad.
thanks for the tip. kind regards.
 We find using baking paper doesn't hold the heat like the Al-foil does.
The baking paper also can catch fire very easy if it touches any heat.
We purchased a couple of sheets of that black plastic looking stuff from a country market.Fantastic to use on the hotplate or grill when you may need to use a dodgy c/park BBQ,just wipe it and roll it up till next time.
We got some of that too Westy .
$18 at Bunnings and still going strong after 2 years .
Yes I have used the black sheet many times and it is still working fine.
Happy Camping
Graeme
I was always taught to respect my elders,
but it keeps getting harder to find one.
We got some sandwich bags made of the black teflon stuff too. I used to use them to toast my sandwiches in the toaster at work. You get some funny looks when you put a cheese and pickle sandwich complete with bag in a normal toaster though.
