Post Info TOPIC: Fitting Slide Out Step to Campervan/Motorhome - Brands/Types None Electric
Duh
Has anyone had one of these fitted to their campervan/motorhomes of the none electric variety?
I have seen a few mobile vans fitted with them for passengers in the metro area and was wondering what would be the best type, undercarriage fittings considered ?????
This is what I fitted to our van instead of the original single step. You can get lighter and nicer ones now though.
Cheers Jeff
Duh
Thanks Jeff, looks pretty good, that is fitted to your caravan I assume (ie; not a previous RV)?
Where did you source your step from please?
Duh
Legendts wrote:
Four rows down Vic, far right are the ones I have.
styledeals.au.com/Caravan%20Steps?gclid=CL3u9buGmrgCFUhIpgodw1gA4Q
 Thanks Jeff, I couldn't get that above link to open so used the main part of the link to get this one, see yours as you have said;
http://styledeals.au.com/Caravan+Steps
Thanks for the Caravans Plus link too Jeff, it opened ok !
-- Edited by Duh on Saturday 6th of July 2013 03:27:21 PM
I think I got it from Prestige caravans in Geelong about 7 years ago. The newer ones are much lighter and aluminium. They also look better ill see if I can find a link for you.
Yes it is fitted to our current van.
Cheers Jeff
Cheers Jeff
Some more......
caravansplus.com.au/catalog/index.php
Cheers Jeff
If doing it yourself try a van repairer/ wrecker for a secondhand unit. I found building a small portable step to fit into the van step well when traveling, serves a dual purpose of giving access to the van and a small step to get to those annex fittings without the need to drag out the ladder at times when all you need is a boost
PS mate turned his into a box to store things like his joggers so the animals wouldn't make off with them during the night, also handy for cleaning gear storage
-- Edited by Wombat 280 on Monday 8th of July 2013 09:59:02 AM
Duh
Thanks Wombat,
I have a portable step that I use for getting into the side of the Transit, also use it for SWMBO to get into the passenger side as it is a bit high for her.  Doesn't need it to get out as she slides out.   smile
