Post Info TOPIC: QUICK FILL FOR WATER TANKS;
Quick, simple, done in minutes, no mess.
A 500mm  length of hose that will fit into the small hole in the filler neck, insert hose with a hose click on connector fitted, (just push hose on connector)
Push hose all the way into filler neck so the connector rests against the base of filler.
To fill, simply enter hose  with a clip end into filler hole & push onto connector untill it clicks, turn tap & fill.
To remove withdraw hose & connector just far enough to release the clipon, push joiner & hose back into filler ready for next time.
JC.smilesmile
JC.
bloody clever
brian
Very clever and simple.
NeilnRuth
Excellent!! Off to Bunnings to get the bits to do that today!! :)
http://kiwis-in-oz.blogspot.com.au/
I built one similar only added a small plastic tap out of the AG section at Bunnings to let me control the flow at the filler when the pressure is to high.
Living on the Gippsland Lakes Victoria.
G'day JustCruisin'.  S.W.M.B.O. thinks this is a great idea (sorry I've just been told  it's a brilliant idea).   Must fit this before you patent it.
