Post Info TOPIC: Hi Guys - another question from Trish and Dave - porta loos :)
Hi there again - 82 days to go and counting - question this time is about porta loos.  Have realised that this may be a necessity :) as we are not travelling in a van!  Does anyone know of a good brand that they can recommend - or are they all of a muchness.  We have looked at the porta-potti range and they seem pretty good to me but what does a secretary know about porta loos (not much).  Thanks again - and by the way - you guys have been great with all your answers to my queries - I'm quite sure I will have a few more in the next 82 days !!
I've had a Fiamma Bipot for over 20 years and it's still good. I was looking into some cheaper ones because they were a little smaller to fit in a smaller place and some leaked and stuck to the one I have. I also looked at some Dometic ones that had a pipe type thing for emptying above the tank that looked like a good system.
Smaller tanks apart from the obvious having to empty more often are lower making it harder to get down to, a problem for lots of people.
Janette
I think they are all much the same,but before you buy work out where you are going to store same as they can vary in size and if you want it to go under a bed or some other spot, the height might be a limiting factor re the size you buy.
David
We bought ours out of the Weekend Shopper. Brand new with all the chemicals.$50
Never had to use it much as pretty good at squatting. Now have a loo in this new van so gave it away to my sister and family for their weekend camps in their Camper trailer. I think they are very much all the same but would check out your Trading Post or a site online. So exi in the shops.
Cheryl
We have a porta-potti and have had no problems with it. As someone else said, check out size for where you want it to store. We manage to fit our into a cupboard.
NeilnRuth
We have a small one in the Avan.  Cant remember it ever being used in the last two years.
Although I have put the toilet tent up a couple of times with it inside, I keep thinking what a waste of space this thing is.
Mike & Ellie
I always feel secure having mine in the van and it earns it's place even if not used lol.
Janette
Yes, I must admit, my husband is always very reluctant to get the portapotti out. So far our freecamping has had a loo of some sort. I do object on rare occasions and he has to get it out - especially handy when I had food poisoning one trip and needed it all night!
NeilnRuth
We had one and changed to a Coleman porta potti, as it has carrying handles and a larger pipe for emptying.  Has been good so far.
 Ditto, but we keep it "just in case". Thankfully "in case" hasn't happened and hope it never does.
Cheers,  Gerty. ... at home
We also have a Coleman Porta Potti,
I would recommend you get one with a 20l holding tank,
It makes them a little heaver to carry and empty, but you don't have to empty them so often.
Being trying to train the Missis to empty ours, but always get the same reply.............
"YOU do it dear" and there will be a nice cuppa waiting when finished. !!! disbelief disbelief disbelief
kiwijims
From Coast to Coast, We'll see it all.......One Day
U.H.F  CH  18 /40  Say G'day.
JRH
 We carry a Porta Pottie in the van and had to use it crossing the Nullabor between Road Houses as I just couldn't wait.  It was a Godsend I can tell you.smilesmile
If I don't get there today, I'll get there tomorrow or the day after.
John & Irona..........Rockingham Western Australia
The Master
I would suggest a 20litre as well. A lot easier on the knees. Did have a 10 litre but swapped it fo the higher one.
For those of you who have them but never use them, what do you do overnight to relieve yourselves.
I don't always park next to a toilet and if I do I dont always wander around outside in the middle of the night
Happy Wanderer
Don't worry, Be Happy!
I'm with you Marj...........bit higher makes it easy to use, and never need to wander around in the night time !
Rosie
One thing we have noticed, and would probably be ... regardless of what ever brand potti you buy, and whatever brand chemical you use - Once in the tank, the chemical only has about 4 days "holding" before it reduces it's effectiveness.
So, in our case, we have an 11 litre holding tank, used for two people the tank is good for 3 days before full (if using exclusively) but if we were using outside conveniences as well, the chemical would start to reduce effectiveness after four days, even though the tank was not full.
If you use public toilet for "No 2s" and only use your potti for "No 1s", the chemical will not be as effective, it needs solid matter to break down.
Bottom line is, it is not necessarily a good idea to have a big tank (i.e. a 20 litre tank) as you will still have to empty it after three days.
kiwijims
 I have a 10litre because of the weight problem, and also it stows under the bed for travelling. A tad low so I generally put a chair next to it to help me get up again. I try to empty it every 2 to 3 days.
I have tried training the dogs to do this rather yuk job, but I guess I'll have to keep doing it myselfhmm.  And they don't even get my cuppa ready for when I'm finishedno
Cheers, Marianna.
The more I learn about people, the more I like my dogs (Mark Twain)
It would be easy to make a small platform for it, to make it higher. You would have to find storage for the platform though. I'm sure you could get something with folding legs with a dual purpose. Something stable so you don't fall off the potti. lol
Janette
Luckily,   we don't usually have a problem with getting up in the night    to use the toilet.
If we do,   in a  CP  we walk to the camp toilet.
In the bush  we water the nearest tree or bush.
We also have those plastic urinary bottles they use in hospitals.  Just in case.  But I have never used one.
In the event of being caught short in the night and needing to do a No 2   The  10 Ltr  Porta Pottie    is very acessibe from the Avan boot.
We have a stand for it to raise the height.
-- Edited by elliemike on Tuesday 11th of June 2013 10:27:28 AM
Mike & Ellie
Thank you all for your comments and advice. Much appreciated. :)
You can buy female urinary devices now that you don't even have to drop your dacks to use. A sheewee is one of them.
Janette
We've had 3 10lt buckets for ages. Red for overnight, blue for waste water under the sink, white for drinking water. As for me, I don't usually get up in the night. Portapotti is there if there's an emergency.
NeilnRuth
I hope no one is colour blind! lol
Janette
 maybe a his and hers a sheewee for her and a urinal bottle for him called a bottlehim. !!! one in pink and one in blue ..wonder where they would get emptied in the morning.!!!!!smile
Time To Sleep Later In Life.
Pity we can't use them on the trees in the CP - neighbour has just told my hubby he has used it to water his citrus trees and they have never looked so good!!
NeilnRuth
