Post Info TOPIC: GN Times problem
GN Times problem
Tried to upload it here but no luck - files have to be less than 2MB
-- Edited by D and D on Friday 7th of June 2013 10:12:04 PM
See you on the road
Master (of Mischief)
I have always saved the PDF file to my desktop but once opened today (ver 47) it will not open in my PDF reader, anybody else having the same problem?
Why do you need it mate, I didn't think wombats could read.
Mine is so slowopening, that I tried Cindy's advice, about right-clicking on the Link, but the remedy she suggested does not appear on my page.  Have PM'd her.
 Some wombats can read, Mrs W reads it to me biggrin
 Sheba, r u having the same problem?
I'm not even getting it anymore. I think I've only been able to open it once!
NeilnRuth
 I think you need to register with Cindy to get it, send her an email if you want it each time it comes out, I don't mean send her an email every time it comes out only one email should do. biggrin
I just tried right clicking the link and now have a copy for Mrs W to read to me. biggrin
No problems for me. Downloaded fine, saved to the desk top without any probs. What pdf reader are you guys using? Try Foxit Reader it does a lot more than Acrobat - http://www.foxitsoftware.com/downloads/
Mr D
See you on the road
no probs for me either
KathnDave
Don't Worry Be Happy
 Finally got it, but it took so long I nearly cancelled it.  It's not usually that hard to get.  If it happens again though, I'll forget about it.  I just can't afford [literally] that much time Downloading one thing.
I've never had a problem with it. Downloads fine for me.
Janette
http://www.thegreynomads.com.au/GreyNomadTimesIss47.pdf
http://www.thegreynomads.com.au/GreyNomadTimesIss46.pdf
http://www.thegreynomads.com.au/GreyNomadTimesIss45.pdf
http://www.thegreynomads.com.au/GreyNomadTimesIss44.pdf
http://www.thegreynomads.com.au/GreyNomadTimesIss37.pdf
-- Edited by dorian on Saturday 8th of June 2013 08:57:19 AM
I also use Foxit Reader,never been a problem
Downloaded latest issue,works fine.
Retired Electronics Tech
Amateur Radio Callsign VK2CJO
I must be unlucky as i haven't even received issue 47 to try & open it yet.
Can anyone put up the pdf so i can load it on my laptop as i don't want to miss
them as they are good reading.I tried going into the back issues but mine only
goes up to issue 36.So thanks in advance for any help
Yendorane
Any day I wake up, is a good day
Wombat, I used to get it but since our new forum format I haven't been. I've told Cindy but I've given up and wait until they are posted on the front page as archives.
Yendorane - Cindy posts the GN News on the front page of forum in archives so you can check out back copies. You'll find them under "Nomad News' - one of the tabs at the top.
Also just saw it's at the bottom of the page I have opened now.
-- Edited by neilnruth on Saturday 8th of June 2013 03:26:01 PM
-- Edited by neilnruth on Saturday 8th of June 2013 03:26:42 PM
NeilnRuth
If you would like to download all the past GN Times issues, then here is a method for Windows users, including Windows 98.
Download and install WGET:
http://internode.dl.sourceforge.net/project/gnuwin32/wget/1.11.4-1/wget-1.11.4-1-setup.exe
Open your preferred text editor (eg NotePad) and copy and paste the following block of FOR lines into your new text file. Then save it as GNTimes.BAT. Put it in the same folder as WGET.EXE. In my case this is "C:\Program Files\GnuWin32\bin". The file must be saved in Text format, not DOC format.
for %%i in (1) do wget -t2 -nc -P\GNTimes http://www.thegreynomads.com.au/GreyNomadTimesIssue%%i.pdf
for %%i in (3 2) do wget -t2 -nc -P\GNTimes http://www.thegreynomads.com.au/GreyNomadTimesIssu%%i.pdf
for %%i in (9 8 7 6 5 4) do wget -t2 -nc -P\GNTimes http://www.thegreynomads.com.au/GreyNomadTimesIss%%i.pdf
for %%i in (9 8 7 6 5 4 3 2 1 0) do wget -t2 -nc -P\GNTimes http://www.thegreynomads.com.au/GreyNomadTimesIss1%%i.pdf
for %%i in (9 8 7 6 5 4 3 2 1 0) do wget -t2 -nc -P\GNTimes http://www.thegreynomads.com.au/GreyNomadTimesIss2%%i.pdf
for %%i in (9 8 7 6 5 4 3 2 1 0) do wget -t2 -nc -P\GNTimes http://www.thegreynomads.com.au/GreyNomadTimesIss3%%i.pdf
for %%i in (7 6 5 4 3 2 1 0) do wget -t2 -nc -P\GNTimes http://www.thegreynomads.com.au/GreyNomadTimesIss4%%i.pdf
Now click on the BAT file and you should see each issue being downloaded one by one. The destination folder is \GNTimes.
-- Edited by dorian on Saturday 8th of June 2013 03:58:49 PM
-- Edited by dorian on Saturday 8th of June 2013 06:00:48 PM
-- Edited by dorian on Saturday 8th of June 2013 06:29:06 PM
-- Edited by dorian on Saturday 8th of June 2013 06:31:05 PM
GNTimes.bat (0.8 kb)
Thanks so much for that Dorian
Cheers Yendorane
BTW, the URL for Issue 35 incorrectly points to issue 36.
http://thegreynomads.com.au/newsletter-signup/
Thanks for that. but as i said i went back into the archives & on my screen it only goes
up to edition No 36 & nothing after that. But dorian put up the pdf for No 47 & i downloaded from there, so
all's good at the moment.
Cheers Yendorane
How do you know all this stuff Dorian?   it seems to me that you have a background in computers.  Maybe programming?... i have read many posts where you have provided IT help to many of us .... Well done and thanks ... Help so readily given is under valued by many ....
The Maccas ....
2013 Avida Esperance Motorhome - based in northern NSW.
I'm an electrical engineer and I've been involved with computers since the 1970s. I can write programs, but I'm much more into hardware than software.
BTW, I've just uploaded the BAT file, so everything is done for you. No editing necessary. All 47 issues amount to about 98MB.
Hi Dorian,
Great info there about the GN News & BAT files, also great to have you on GN.
Some time ago a member here was asking about a program for using Google Earth to log in where in Australia you where while travelling around Aus, so that other members on GN could also track their progress and know where other members are at any given time.
Do you know of such a program? that we could all use to see where each other is in our wonderful country?
Or perhaps its a project you could work on for all of us if you have the time to spare.
