Post Info TOPIC: Jaycar !0A
Jaycar !0A
It seems Jayar have got the message ;):)
http://www.jaycar.com.au/productView.asp?ID=MS4044
Note: there is NOW NO reference to RV use :D
Could still be more to come ;)
PeterQ
Duh
Looks like they have decided to cover themselves by not giving the wrong impression of an item to make a sale.
Probably running scared of litigation. hmm
I suspect they got a message from authorities, that the earlier Adv claiming it suitabilty "for
CONNECTING A VAN to a 10A outlet when no 15A was  not available" was not acceptable
PeterQ
I understand that there are standards related issues, but what's the real safety issue? The device has a 10A circuit breaker, so it's not as if you are going to be drawing 15A from the outlet. What claim did the original web page make that differs from the current one?
BTW, Jaycar's web site is down at the moment, so I only have access to this archived page:
http://web.archive.org/web/20130512164516/http://www.jaycar.com.au/productView.asp?ID=MS4044
-- Edited by dorian on Thursday 23rd of May 2013 03:12:36 PM
Duh
You are probably right Peter, a lot of sparkies out there like yourself that would have picked up on the safety issue.
Yendorane wrote:
So what your saying is that it can't be used to plug your caravan in from a 10 amp household power point to run lights / charger etc
 I can't see this being a problem is as long as it's "not used in the rain or exposed to weather" (to quote Jaycar). I use one of these at home and it sits inside the laundry out of the weather and is plugged directly into the laundry power point. My van also has an RCD and all GPOs (techiespeak for power point) are two-pole switched (per legal requirements).
 I also use mine around the house when I need the protection of an RCD (techiespeak for "safety switch"), especially when using my electric hedge trimmer.
 By comparison the Ampfibian is an all-weather device suitable for outdoor use.
-- Edited by jimricho on Thursday 23rd of May 2013 06:45:27 PM
Merda tauris scientia vincit
Excuse my ignorance, but doesn't an "Ampfibian" do the same thing? Or is the problem that the Jaycar unit is not weather proof.
Any day I wake up, is a good day
Thanks for that but its a lot cheaper than the ampfibian
Cheers Yendorane
