Post Info TOPIC: Bug & Tar remover
Bug & Tar remover
Any good home made recipes to remove Bugs and Tar,its as dear as poison to buy. Thanks
smile
Kero ?
 Cheers, Chris...
WD40.
JC.
not sure about the tar, but carb soda mixed to about the consistency of  custard is good for bugs and won,t harm the paintwork.
That WD40 or RP 7 works well not much difference to kero but easy to apply. I squirt it onto a cloth so I can control the area under cleaning
Try a bit of diesel on a rag for the tar.
Lance C
You can buy a 350gm pressure pack of 5star bug and tar remover from most $2 stores or Big W for less than $4. It will last a long time.
preen is good for bugs and turps for tar.
Some scrunched up green grass is as good as any thing .
Time To Sleep Later In Life.
50/50 kero and liquid detergent,,, sponge on,, then wipe off with clean water/rag.
-- Edited by Baz421 on Friday 19th of April 2013 04:54:54 PM
This has been mentioned before and if tar is ingrained on the front vinyl, NOTHING will remove it.
I now use a vinyl protector on the new van and this has worked ok so far.
Dick.
If you want to remove TAR from vinyl I have done this several times ,I used petrol on a rag took it of easy then wash with detergent and water came up like new,only use Caltex petrol (only joking ).
Lance C
 Damn inflation.....
 another great natural remedy... I thought grass was for smoking? Although smoking causes cancer.
Got to keep moving and as Hippocrates the modern medicine guru once said "Let food be thy medicine and medicine be thy food
If you smoke enough you can sit back and try to count the bug and tar spots as a form of relaxation
