Post Info TOPIC: FRIDGE FAN
TAJ
FRIDGE FAN
would a small dc 24v 1.8w fridge fan work on 12v if so is it safe
    thanks suenrayconfuse
I'm no expert but from my limitied knowledge of electricity and small DC fan motors I'd say it will spin but at much less than optimal speed.....possible also overheat due to the inefficiency so it could be deemed a hazard???. 12V computer fans come in small and large sizes and are pretty cheap so that may be the way to go.
Do you want it for the inside or outside of the fridge?
TAJ
will be using the fan for exhaust outside the fridge
suenray
Taj,
these fans are the pick with their low power draw. I fitted one recently and it works very well.
http://search.jaycar.com.au/search?w=yx-2574&view=list
Yes ,It will work OK & not be harmed[is safe]
 It will run much slower & not move as much air , so might pay to just connect to a 12V battery first & check is sufficient
It will draw a lot less current .than on 24V
PeterQ
-- Edited by Santa on Wednesday 3rd of April 2013 11:02:16 AM
Santa.
TAJ
THANKS for posted information put the 24v on works okay for now
  suenray
 Used two of these to replace noisy ones in my Jayco Westport internally mounted 'Power Supply'.
Seem to have a similar air flow & are very quiet.
I use old PC cooling fans for my incorrectly installed fridge.  (Its top vent is level with the bottom of the condensor fins ... have reduced the opening to train the air flow over the fins & installed two fans).  Noise is not an issue for them I find.  Turn them on with a switch that has an inbuilt light as a reminder.
12 volt units less than $20.00 and works very well. Mounted one top and bottom Mounted mine inside the vent with cable ties can't see or hear them
