Post Info TOPIC: Please Help
Please Help
Could some kind person,please help me out regarding a problem i have on my email , every time i go to send a email this popup message appears ...it has my email addy on it and then asks for a password.I cannot get into send any email ,but can send emails.I Thanking you in advance for any help you maybe able to give me to resolve this annoying problem.Other wise i will have to head to a putter Dr i guess.
Regards Herbie.
Time To Sleep Later In Life.
I have just sent you a private message.
I cannot explain the answer in writing ( I need to talk to you )
Hoping everyone has a pleasant and safe journey
all the best from
Liddle
Howdy, do you have a mac? if so try this. More details about your operating system and email programme would help. You have what seems to be a common problem and found this on goggle.
Before you start, check you have got the correct password for your email account(s), you need to open up Keychain Access, via Applications, then Utilities. Click Passwords (or All Items) on the left, and look for the email passwords (should start with mail.)Look for repeated entries for the same account. I have 5 email accounts, 2 of them had 3 passwords, and 1 had 2 passwords. The others had one password, and were working fine.
Now, just delete the oldest of the repeated passwords, so you are left with just one for each different email account, which being the most recent, should be the correct one.
Regards Herbie.
 Sorry I can't help herbie, but this doesn't make sense to me.
Which e-mail program are you using ?  Has this just occured now or been happening for a while ? Only respond if other suggestions you have received do not work.
I am useing enternet explorer my server is through big pond. i had some problems re telstra service and like someone else on here, had to ring someone in  India or where ever to sort my problem out,now i find i have this problem and believe me if anyone has had to ring Telstra for help ,one dosn't want to have to do that again so soon.I went and googled but cannot understand .Hope this bit of info may help to understand my problem.
delete your email account then re install it best solution i can offer
I have a very similar problem. Have tried all sorts to fix it, get the same msg as you through my yahoo account using Microsoft Outlook. Can recieve but not send. None of the fixes I tried worked so I just opened a Gmail account and that works fine, I think mine originated from a problem with outlook where I had a problem and could not access the data file. ran a repair program Stellar Phonix, fixed outlook but this problem popped up just after. have no Idea on how to fix it.
http://followpeteraround.blogspot.com.au/
Try this:
I assume your e-mail account is xxxxxx@bigpond.com or xxxxx@bigpond.net.au.
If you are using the e-mail program that comes with Internet Explorer, you are using Outlook Express. You dont state which Windows program you are using. I am using Windows 7 with Windows Live e-mail program. Live is similar to Outlook Express, so lets go:
Open the program, in top left corner click the drop down Menu and click on Options. Your e-mail program will show. Highlight the e-mail address and click on Properties.
Page 1 is headed General: Under Name put the name Herbie or whatever you want to appear as the message sender.
Under Organisation, leave blank
Under Mail Account, put your complete e-mail address
Under reply address, leave blank
Put a tick in the box Include this account when receiving mail or synchronising
Tick no other boxes.
If you make changes or add any detail, click Apply then click OK
Page 2 is headed Servers: My incoming Mail server should read A POP 3 Server
Incoming Mail (POP#) should have.... mail.bigpond.com
Outgoing Mail Server (SMTP).... mail.bigpond.com
Incoming Mail Server:
E-Mail User Name: xxxxx@bigpond.com or xxxx@bigpond.net.au
Password: Insert Password which will look like this .........
Tick box Remember Password
Tick no other boxes
Outgoing Mail Server:  Do not tick any boxes
Page 3 is headed Security:  Touch nothing on this page
Page 4 is headed Advanced: Under Outgoing Mail (SMTP) 25 should be in the box
Incoming Mail (POP3) 110 should be in box
Touch nothing else.
Click on Apply then click OK
I hope you can follow that procedure. It works for Windows Live. Its a long time since I used Outlook Express but they are similar and Im sure the same procedure I have described will work for you. Let me know. Usually these problems occur because a tick has been put in or left out of a box or a word misspelt.
Ken.
 Never used Outlook, so a bit of guess work here. It's part of Microsoft Office.  Suggest you check your version of Yahoo Messenger and mail. Make  sure you have the latest version. You can download these programs without uninstalling the earlier versions.  After you have downloaded and installed the latest version, delete the e-mail account from Outlook. Reboot your computer and install Yahoo Mail again. See if that helps.  What version of Outlook do you have ? The latest version is 2010. Versions earlier than 2007 may not accept Yahoo Mail.
Gmail and Yahoo Mail and Hotmail are not email programs that are installed on your computer, they are what is known as Web Mail and are accessed using a browser such as Internet Explorer or Google Chrome
The email program Outlook Express is installed on your computer and was installed as part of the Windows operating system, until Windows 7, these Windows email programs are used to access your mail, in your mail box at your Internet Service Provider [ISP]. These email programs can also be used to retrieve emails from your web email mail boxes you may be subscribed to.
Outlook is the email program that is mainly used by business and is capable of doing a lot more things than Outlook Express but is not usually needed by us Grey Nomads.
Until recently Outlook came in all versions of the Microsoft Office which is a suite of programs, but the program Outlook now is only supplied with the Business version of Office.
David
True, Hotmail, Gmail, Yahoo Mail and others are stand alone programs but can be added to Windows Live Mail and later versions of Outlook and Outlook Express.. No reason why Herbie cannot access mail thru the YM website but apparently he chooses to do it thru Outlook !
Thank you to everyone who responded to my Yell !! for help...You guesses it i had to ring Bigpond once again (55mins on the phn just to speak to someone in India )They had to give me this bigpond code to put into this popup thingo that kept appearing in email...The service one gets from Telstra is really third world service,Just terrible to have to go through all the crap just to get hold the line , you have a 55min wait.For the money Telstra charges the service should be the best in the world.
Hi Herbie
The bigpond code that you now have from Bigpond is your password for bigpond and every now and then that screen will pop up and ask for your password so dont lose it or you will have to go through all this again.
all the best from
Liddle
Hi Liddle, yes you are spot on in describing what the problem was ,,,,and no i will not be loosing this code, just another piece of baggage to carry around .Who needs all this teco stuff !!!! I guess we all do,as this is the world we live in.
Have you tried using the App called KEEPER on your mobile phone. You can store all your passwords, codes , bank details, passport etc in a secure location. We have all login details stored here and it has proved to great help when the old grey memory bank fails. It is a free app or you can pay $9.90 for a year. We just use the free version. Trust you have solved your other isuue.
Thank you for your beaut advice re the free app , i have just sorted it out on my phn ,so now i am not bogged down with trying to remember so many diffferent numbers,codes.and freed up the grey matter a little. huhu
