Post Info TOPIC: SEMI 0FF ROAD
SEMI 0FF ROAD
We are currently looking for a van to head off for a minimum of 12 months - leaning towards dual axle but want an off road van to give us the option of going bush (which we love).  Many vans state they are semi off road - if anyone has one, can you advise what restrictions there are, some of the places you have been and any other advice.  Cheers.
SCOEY
Life is not tried if you merely survive.
Welcome to the forum Scoey. The search for the "right" van is fun but can be very difficult, wish you luck with it!
Start with a list of things you must have, things you'd like, how much weight you can tow with your vehicle, and budget limits. Then add all the places you want to visit, and consider the conditions you would be in. Easy!
We have a Jayco Discover pop-top "outback"... the chassis is stronger, and the clearance is higher, but the internal fittings are standard Jayco. It is ok for dirt roads which are not seriously corrugated, and water crossings below floor level. If you shake it to bits on a corrugated road the warranty is voided. We've been to lots of places you wouldnt expect to get a normal low-clearance van into, even service stations are easier! Its NOT an off-road van, but was much lighter in weight, and less expensive than true off-roaders, so we compromised. If we really want to go bush along bad roads, we leave the caravan behind and take a tent for a day or 2.
Cheers,  Gerty. ... at home
I can't help much with the info but welcome from me SCOEY, enjoy here and out in the playground.
I have read that the "Kedron" and "Trackmaster" are good off road beast's. If ever I upgrade from my big rig I would be looking at both of these first and probably in that order.
We were very happy owners of a Trakmaster for 14 years, until the Driver was no longer able to tow.
The bigger you get, the more restricted you are about where you can take it. Single axle more manoeverable than double.
Our van was only 14 foot inside, but we managed to live full time in it for three years, then did heaps more shorter periods in it after that. We have been told that 16 foot is max length for versatility.
We travelled a hell of a lot of corrugated tracks. Trakmaster chassis was nice and solid, everything inside stayed attached where it should. The pic on the left is indicative - that track was 63km long, like you see - and we had to go both ways on it. No problems.
-- Edited by wendyv on Monday 11th of March 2013 09:55:15 PM
wendyv
It dosn't really matter what you buy , for some reason they all have the same fit out inside.Which is a big down fall with a lot off off road vans. The van we had before this one was off road and it was really off road in name only and it was one of the top brand names.
Time To Sleep Later In Life.
Maybe have a look at the Nova Terra Sportz. I like the build quality and the extras that are included as standard.
2011 Toyota Prado 150 SX T/D Auto (3 door)
2013 Nova Terra Sportz Pop-Top
Living the Dream !!
Duh
I believe the Blue Heeler have a good reputation
http://www.google.com.au/search?q=Blue+Heeler+Caravan&hl=en&rlz=1T4GGHP_enAU503AU503&tbm=isch&tbo=u&source=univ&sa=X&ei=D2U9UdLTF4uLkwWUmIGwBw&ved=0CFcQsAQ&biw=1067&bih=496
http://www.caravancampingsales.com.au/reviews/2012/caravans/sunland-blue-heeler-xtreme-off-road-28389
 http://www.caravanworld.com.au/latest-reviews/article/articleid/79071.aspx
Here's a 2nd hand one for sale;
http://www.caravancampingsales.com.au/used/sunland/blue-heeler/
Thanks to all for your responses and for the welcome - seems like a great forum - looking forward to lots of interesting info.
Cheers.
SCOEY
