Post Info TOPIC: tv dongle
tv dongle
hi all
has any body used those laptop tv dongles to watch tv on a laptop while on the road
cheers snap
-- Edited by snap1946 on Thursday 7th of March 2013 08:13:36 AM
Hi Gorden
Yes we have 2 of them what we use , one for the laptop and the other for mine PC to record TV programs
works like a dream
but we use lately a small HD tv what is using only 30 watt/hr what is much less the the laptop what is using 90watt/hr
that is the only reason why we have the small tv now
Regards John
Cruising Cruz wrote:
Hi Gorden
works like a dream
but we use lately a small HD TV what is using only 30 watt/hr what is much less the the laptop what is using 90watt/hr
that is the only reason why we have the small TV now
Regards John
 HI JOHN
I DON'T MEAN THE ONES FOR RECORDING THE ONES THAT ACTUALLY PICK UP TV STATIONS
I think that is what he meant snap1946, thats the way i read it anyway...
Great idea to purchase a small HD TV now days, laptops are running the hard drive, fan, and processor... all using more power than a stand alone TV will.
But a dongle is a good idea for those with space issues...
A DVB-T/DAB/FM dongle can also be used for a lot more than just TV for those interested in other media streams.
Cruising Cruze wrote:
Hi Gorden
works like a dream
Regards John
 How do you do that John. I have one that I bought but haven't used yet.
 Gail
"Started wandering and don't wish to stop!"
Hi Gorden ,
that's the one I mean , the one where you connect an antenna cable to
we got a while back 2 from Aldie  for around 35 dollars each
hope this will help you
Hi Gail
you need the TV Dongle and a antenna
stick the TV Dongle in laptop or PC install software that came with it ,
scan for channels and you are ready to go
very simple setup it is
if you get into trouble give me a yell and I try to help you
regards John
The only issue I found with the one I have is that the reception is no where near the potential of a good topbox or quality TV's tuner.
no problem at all with it
we watch the programs what we recorded on a 42 inch screen and it is as clear as the TV itself
Cruising Cruze, thanks for reply but I really meant how do you record the TV programs? I have watched the TV programs on it when i got it to see that it worked!
 Gail
snap1946 wrote:
 HI JOHN
 The dongle is just a TV tuner (or sometimes it contains 2 tuners.) It comes with software so your computer can display the output of the tuner on the screen. There is also software that comes with the dongle and allows the computer to record the programmes to your computers hard disk if you so require.
Thanks Peter that's the way it works
on the volume bar and channel change the is most likely an red button that's the one for recording
in the program setup you have to tell it where to store your recorded tv programs
hope that this will help a bit Gail
